New Kubota..loader edge?
/ New Kubota..loader edge? #21
how flat are your area's? it has to ride on the shoe's, if you have high center points your going to need at least 3
i have only 2 on my 54 inch bucket, it works fine, i run in float 95% of the time.
I would say my yard is mostly reasonably flat, ordering 3 instead of 4 tamers would save about $72 so total cost would be about $216.93
I do really like how easily those tamers appear to be installed or removed.
The first 29 years I lived here a 8N Ford tractor and a rear blade was the main way I plowed my snow, last year I bought a new tractor with front loader and rear blower and it’s been working great
/ New Kubota..loader edge? #22
use code ttwt, it will save another 5%, yea single bolt, per tamer, each side, i put them as about 2 inches from the edge
/ New Kubota..loader edge? #23
Ordered 3 4 inch tamers, thanks to your discount code I saved $9.75 total price $209.32
I have a mile long gravel driveway. A large yard and mailbox area to clear. I NEVER considered my bucket for snow removal. Good HD rear blade and go like the wind. No stopping to dump the bucket - snow is curled off the side of the driveway, yard and mailbox area - clear, unobstructed view out front.
I simply don't have time to play with the snow with my bucket.
Ok! Where do I get a rear blade? I'm looking at the diy pipe.weld thing too.
A twisty humped long driveway...
/ New Kubota..loader edge? #27
Here is a video of my tractor with the edge tamers. I have just two on (recommendation was three)
Gravel drive.works well in light and fluffy or in heavy snow too.
/ New Kubota..loader edge? #29
/ New Kubota..loader edge? #30
If edge tamer’s are really required a couple of pieces of square tubing bolted to the underside of the bucket should work. Just put a strap of steel on the tubing ahead of the bolt heads so they don’t leave scratch marks. Or drill a larger hole to access the bolt head.
Rear blades don’t work well if the snow gets too deep to drive thru or the side windrows get too large/frozen to move. They may also turn a lighter tractor sideways With a heavy load.
One may notice municipal graders just have a normal blade or serrated cutting edge for moving snow/ice.
/ New Kubota..loader edge? #31
I have a set of edge tamers (2 for 6' bucket) and they work very well on gravel. I also use them on occasion when moving mulch around or pushing in a burn pile.
I generally don't use my bucket for snow plowing, but I need to have a solution for the rare gravel drive that I may need to clear. This year I'm using uhmw polyethylene cutting edges, front and rear blades, on pavement and concrete.
The snow edge posted above is also a nice bucket solution for pavement. I used one of these on my previous tractor, and they work very well, and are heavy duty. I sold mine to a neighbor who uses it on his very short driveway.
/ New Kubota..loader edge? #32
It all depends on the property. There are sections around my place that the FEL would be ideal... but the long lane drives the rear blade and SB on front for me. NOBODY is challenging anyone's snow weapon choices!
I've had 3 different blades trying to get the right one. My first one was an old Land Pride 6' rear with adjustable shoes... $200 on CL. It was a great blade! Heavy and had a great moldboard shape that really rolled the snow. My dealer installed a quick hitch for free when he kept my tractor an extra week doing a service. The old Land Pride blade was not QH compatible and it did not offset. The lane did get narrower as the season went on without blade offset!
I traded the LP for a Frontier RB2072 (I'm a retired Deere engineer so wanted to buy JD). Oh man... don't buy Frontier. It would offset (by unbolting and shifting the blade... NOT ideal) but the moldboard shape was terrible: too flat! It wouldn't unload; sold it the next summer.
So looking for a heavy, easy offset blade with a decent moldboard shape (many miss the mark here)... I bought a Rhino 5006. Same cost as the Frontier but way better build quality, QH compatible, weight, and moldboard. She's a keeper.
If you're new to using a rear blade, this snow lesson from Everything Attachments was invaluable to me starting out. He illustrates proper usage clearing off a parking lot. Reversing the blade and going into "bulldozer" mode is how you handle the BIG piles and drifts.
/ New Kubota..loader edge? #33
You are right that some blades are just terrible.
In fairness...they are designed for dirt and loose material. So they arent really designed with rolling snow at speed in mind...
Frontier did get it right with the 2308 though. Thats what I have and use for snow. And it rolls snow as purdy as any snow plow I have ever seen.
/ New Kubota..loader edge? #34
Great to know! I feel terrible saying 'I hated the product' but feel better knowing they have some good ones too!
/ New Kubota..loader edge? #35
Hi. We just got our new Kubota LX3310. Snow is coming. What can we do to protect the loader's bucket 60 inch edge from our tired paved tar driveway? Thank you for your help!
FallLine Corporation makes heavy duty polyurethane bucket edges for snow removal. They also have polyurethane edges for snow plowing. I have both and am very satisfied with how well they work.
Fallline.com
/ New Kubota..loader edge? #36
Not mine, but same thing. You can see the nice curvature to the blade. It rolls snow very nicely
/ New Kubota..loader edge? #37
I have an asphalt drive (3 years old) and had it sealed this year. The seal guy suggested going to poly or rubber so I just installed a 1" FallLine edge too... good to hear you like it. Fingers crossed.
Yeah!... that is a beast! Nice moldboard shape. So anybody out there looking for a blade, don't assume they will all work the same. They don't. Look for features sure (offset, tilt, QT), but weight and a nice moldboard shape that will roll the snow are tops.
/ New Kubota..loader edge? #39
Yup, it's a helluva blade for dirt work. Moving snow a couple times a year is a bonus.
The only downsides compared to some of the other similar 1200-1500 pound rear blades is the angle and offset only go ONE way from the seat.
Of you want to angle or offset the opposite way....you have to pull a couple pins and put the cylinders on the opposite side
The way I work it....angle one way, offset the opposite. IE: if I want to windrow left....that's angle. If I want to windrow right, straighten out the angle and use offset. If that makes sense to you...
/ New Kubota..loader edge? #40
You can order one from the tractor supply store in Ithaca if they do not have one in stock and it should be here next week if not sooner as they get a truck/delivery every couple of days on average.
John Deere 2840 Tractor (A64047)
John Deere 2840...
2000 Jeep Wrangler 4x4 SUV (A61574)
2000 Jeep Wrangler...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2008 Toyota Rav4 SUV (A61574)
2008 Toyota Rav4...
2022 JOHN DEERE 26G EXCAVATOR (A64279)
2022 JOHN DEERE...
