45-50hp Help
/ 45-50hp Help #1
Mudlick
Member
Ford 1310
Looking at 45-50 hp tractor to manage 10 acres of mixed wooded/mowing property. Primarily interested in Loader and grapple work. Only dealers close are Kioti, New Holland, JD, and a Massey rep. Like Kubota but nearest rep is 45-minute drive. Not looking for top of line models, but one with hst. Thoughts?
/ 45-50hp Help #2
Can't help you really. Your avatar nor posting states your regional locale.
/ 45-50hp Help
Sorry. New to the forum. I’m in southwest Virginia.
/ 45-50hp Help #4
I have a Kubota a little below the hp your looking at. Really happy with it. Not sure if Messicks is close but they have a lot of respect amongst us Kubota owners.
/ 45-50hp Help
About 5 hours. Closest kubota dealer is 45-minutes. wondering if kubota l4701 or mx5200 is worth the extra drive over kioti 5010, new Holland workmaster or boomer in 45-50 hp (kioti/NH dealer 5 minutes away)
/ 45-50hp Help #6
Kioti DK4510 HST
NH Boomer 45 (T4B)
MF 2850 M
JD 3046 R
Other options if you don't mind looking a little further...
Branson 4820h
TyM 494 hst
LS 345 he
You get more tractor for your money with these, but there are a lot of variables that only you can answer.
/ 45-50hp Help
Kioti DK4510 HST
NH Boomer 45 (T4B)
MF 2850 M
JD 3046 R
Branson 4820h
TyM 494 hst
LS 345 he
Those models over kubota is your recommendation, did I read that correctly? I have a mix of flat and hilly land
/ 45-50hp Help #8
The TYM line is really coming on strong. S Korea I think? I chose Kubota because my dealer has 3 locations within 25 miles. Closest is 3 miles down the road. I live on state line and I think they do a heck of a business with our Hoosier friends to the south.
/ 45-50hp Help #9
How often will you go to the dealer? Typical home use is 100 hours a year or less. You will need to do an annual engine oil change and transmission oil change every few years. That's like one trip a year to the dealer at most.
My dealer's 3 hours away. I have been there twice in four years, once to test drive and once to pick up a backhoe. They mail the filters I need for maintenance.
/ 45-50hp Help #10
It really depends, I wasn't trying to make a statement about Kubota either way. The L4701 would be the nearest equivalent. Among those models, the 4701 has the lowest capacity loader and is a lighter tractor. You would have to step up the the Grand L. 4760 to be comparable, you didn't want high end though... ;)
/ 45-50hp Help
I would hope I wouldn’t have to go often to dealer. Mainly if there were problems beyond regularly scheduled maintenance and such
/ 45-50hp Help
Makes sense, thank you!
/ 45-50hp Help
You will receive better quality replies if you add Southwest Virginia to your T-B-N PROFILE.
Done, thank you. Wasn’t sure how to do that at first
/ 45-50hp Help #15
De nada. I have a giant spreadsheet of specs on about 45 35-60 HP machines from 9 manufacturers in various weight classes. I've got almost 20 acres of mostly pines to manage. I want the SS transmission, but these all have both as options. The hard part right now is finding one on the lot to test drive.
/ 45-50hp Help #16
Depends on your budget...new, or used? Open station or cab?
That said, I'd suggest seeing what your local Deere has...
As far as specific models, consider a 4120, 4320 or a 4044. All of these tractors range from 40 to a bit less then 50 engine HP. PTO HP will be 10%-15% less then engine HP. All have strong loaders and, if buying used, the extra hydraulic remotes you need will may already be installed.
I've had Deere tractors for 20+ years....never bought a new one. Used Deeres have been very good machines
  • Good Post
Reactions: JWR
/ 45-50hp Help #17
Looking at 45-50 hp tractor to manage 10 acres of mixed wooded/mowing property. Primarily interested in Loader and grapple work. I have a mix of flat and hilly land.
Tractors generating this power will weight 3,700 pounds to 4,100 pounds bare weight.
The fundamental importance of TRACTOR WEIGHT eludes many tractor shoppers. Tractor capability is more closely correlated to tractor weight than any other specification.
3,800 pounds bare weight is the mid-weight of compact tractors, a high unit volume segment. Every tractor manufacturer offers at least two models, an economy and a deluxe tractor, in this weight range.. All offer HST. All are 66" wide, plus or minus a smidge. All will comfortably pick up 2,000 pounds 18" with the loader. Horsepower options are 40-horsepower to 60-horsepower.
45-horsepower will adequately power a 72" medium duty Rotary Cutter / Bush Hog through tall grass.
Tractors are inherently unstable engaged in Loader work. Tractor rear wheel/tire spread, sometimes adjustable, is a critical factor increasing compact tractor stability. Rear axle is the tractor component on which rear wheels/tires mount. A 6" to 10" wider rear axle substantially decreases tractor rollover potential. Tractor width is an approximation of rear axle width.
Closest dealers are Kioti, New Holland, JD, and Massey Ferguson. Kiioti/NH dealer is 5 minutes away.
The Three Point Hitch tractor has been marketed in the USA since 1939. Patents on the Three Point Hitch and TPH hydraulic controls expired in 1955. Since 1955 (66 years) all traditional compact tractors have been designed and produced around the Ferguson Three Point Hitch, worldwide.
The traditional Three Point Hitch tractor design is generic.
Start with the nearest dealer and work out.
Transporting a tractor for service is expensive and inconvenient, whether you trailer it or the dealer trailers it.
CREDIT: 'FELIXEDO'
"It has been touched on a couple of times, but not directly as a buying factor.
Every major make has a machine that will do the job(s) you want. Check out your nearby dealers, and go with one you have confidence in.
A great machine with no support nearby is a hassle to repair and maintain.
And a good machine can't make a lousy dealer into a good dealer."
/ 45-50hp Help
Open to new or used. No cab. Local Deere only has two 5055e’s and the rest are 1023s. Those are a bigger than I need (taking into consideration that the 45-50hp is already somewhat bigger than I likely need)
/ 45-50hp Help
Tractors are inherently unstable operating on sloped ground. Tractor rear wheel/tire spread, sometimes adjustable, is a critical factor increasing compact tractor stability working sloped or uneven ground. Rear axle is the tractor component on which rear wheels/tires mount. A 6" to 10" wider rear axle substantially decreases tractor rollover potential. Tractor width is an approximation of rear axle width.
Thank you, good to know
/ 45-50hp Help #20
From Tractor Pete's website, there is very little difference in HP and tractor performance from 42Hp thru 60Hp. It's all in the gearing and marketing. ;)
With all that said, most machines in that range are very competitive.
How far away is this place?
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
Bulk Lot - (3) Pallets of Electric Motors & Pump Components - Selling as One Lot (A63689)
Bulk Lot - (3)...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
