Leaky Tire
/ Leaky Tire #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
One of my rear tires - 19.5Lx24 - takes a month or two, but will always end up about two psi less than the other. Then I fill it up and some months later it is lower again.
But this morning I went out and that tire was FLAT. The tires are in good shape, tubeless, and wheels are good. I cannot find the leak
What would you do? I'm thinking of calling the tire service guys, but that's a two hour round trip.
/ Leaky Tire #2
Can you put the tire on a small flat bed trailer or get it in the bed of a pickup? Then find a tire shop that also does Ag too.
I have Broadhead Tire some 12 miles from me. A leaking bead was my trouble. The shop had some 'redish-pink' stuff to coat the inside rim lip that seemed like green slime in a way. This revitalized the tire bead and sealed. I'm going on a year now, it's holding the same PSI since it was filled.
PS, come to think more about it, maybe it was reddish RTV. I don't recall. But, whatever it is, it's also used on aircraft landing tires as well.
/ Leaky Tire #3
Slime worked wonders on my Kubota fronts. Foam filled the rears.
/ Leaky Tire #4
Put some dish soap around the valve stem. Tubeless Shraeder valves can leak at the rim after a while. Wiggle it around a bit. Include the valve area with soap, too.
/ Leaky Tire #5
Yep. Thats it!
/ Leaky Tire #6
What would I do???? I'd get it fixed unless i didn't need to use the tractor. Otherwise I'd just FORGETABOUTIT.
/ Leaky Tire
I'll give that valve stem a look tomorrow. Good idea.
That's the kind of thought I was hoping for. It just doesn't seem like a normal puncture; I aired it up today and it is holding. That's not right......
If it comes to taking the wheel off, I
doubt that I'll wrestle it on & off by myself.
Not only is it heavy, each of those 8 lug bolts call for 365 ft*lbs of torque. ugh.
rScotty
/ Leaky Tire #8
A quick fix is sometimes possible with a metal valve stem cap...
The cap prevents loss from leaking schrader core.
/ Leaky Tire #9
I'd check the valve stem. We check all our machines before use anyway.
/ Leaky Tire #10
rScotty
365ft-lbs. Yes. I finger tighten till snug, then hit the lug bolts with the impact on setting-1. Work my way in criss-cross fashion. Then hit them on setting-2 likewise. This gets it very close to that range.
IF these are not tightened enough, over time, they loosen and fall off. I wonder why I know about this? LOL. And they are not any certain bolt either. They are metric lug bolts. To keep them from coming off so easy as 365ft-lbs is a chore to reach, I improvised using Nord-Lock washers just under the bolt heads. This is like using lock-tite. ;)
40' CONTAINER (A62131)
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
500 GALLON FUEL TANK (A62131)
500 GALLON FUEL...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
International Engine (A61568)
International...
2022 Forest River R.pod Towable RV Trailer, VIN # 4X4TRPV28NR208064 (A61166)
2022 Forest River...
