Oil & Fuel Fuel cans
/ Fuel cans #21
4570Man - that's my exact thought. The attendant could not care less what I'm doing out there.
I have four GI 5-gallon Jerry cans. Got them from a military friend in '65 and brought them down from Alaska when we moved. No drip, no spill, rapid empty. But Lordy - lifting a full can and holding it almost blows my bladder.
Time is coming - I'm gonna have to figure some alternate way to lift those cans.
/ Fuel cans #22
Buy one of those drum pumps, then cut down the suction tube so it fits in your can. The threads are the same as your GI can lid. Then connect a hose to the pump spout and leave the can on the ground as you pump fuel.
/ Fuel cans #23
Fill 3 cans to 5 gallons and the 4th to 2-1/2 gallons. Fuel the tractor with the 4th can first, then fill the now empty 4th can half-full from another can. A half-filled can is twice as easy to lift as a full one.
/ Fuel cans #24
i'm surprised your gas station lets you fill up your "oil jugs" with diesel. you must know somebody :)
No I don't... I go to the station (not always the same one) and fill the jugs, over the years I've only had one person say anything to me. (about the color) I kept filling and still go to the same stations, no one has ever said anything to me again.
I do live in a farming friendlily state and not in a city.
SR
/ Fuel cans #26
I have one of those. Hate it. Trying to hold the 5 gal can while you push and hold down that spring button while fuel SLOWLY gurggles away. I like my VENTED VIP Racing can.
Agreed. The no spill cans are nice for filling small tanks but too slow to dump the whole 5 gallons.
/ Fuel cans #27
I’ve used those and they don’t have many good options to rest the can while they’re pouring and the funnel is a hassle to have to clean every time.
What do you have? Girly arms?? :ROFLMAO:
Chuck the attached funnel and get a real one. Drop it into the fuel hole, rest can on edge and open the flood gate works just fine needing a ladder for the fuel filler on the JD.
I have a 50 gal transfer tank with a 120 volt pump all mounted on a plastic skid/pallet. I fork it into the back of my truck when it needs refilling. Leave it on the garage floor and fill the NH that way. Skid takes up a lot of real estate that I'm not sure I'd give up if I had less room.
/ Fuel cans #28
Still looks to be too heavy for me. I've taken to doing it 2 gallons at a time.
With 5 gallon container, I first sit it on the hood and put a syphon in it to take most of it out before pouring the last in.
For the first couple gallons I just rest the jug on the hood and tilt so the spout is in the tank opening. Usually I'll use a funnel. Once the jug is down to 1/2 or so I'll just lift & finish filling. 5 gal jugs here. Don't really have a problem lifting them (yet).
Agree those modern spouts are worthless, replaced all of mine with the replacements they sell for "water jugs" (nudge, nudge, wink, wink).
Now can drain 5 gallons in 30-40 seconds. Not a single drop spilled.
I don't think the screen on the filler neck on my tractor will take fuel that fast. Maybe 1 gal/min.
I doubt the $11/hr clerks at most convenience store/gas stations notice or even care what you're using.
/ Fuel cans #29
You must live in one of them Communist states. In red (?) blooded Conservative states like MS, no self respecting convenience store owner would ever pay more than the $7.50 minimum.
More to the point, my go-to funnel for my Kubota is the top half of a gallon milk jug. The particular one I use has a neck that's fortuitously a press-fit into the plastic neck of the Kubota's tank. And my favorite diesel cans have been 2.5 gal cat litter jugs. I'll have to start recycling my big oil jugs into diesel duty in the future.
/ Fuel cans #30
Maybe referenced somewhat before, but I too cannot easily lift a can up to my tank inlet, but have found these inexpensive battery operated pumps extremely easy to use. They will not totally get all the fuel out of the can, but what remains can then be easily poured into the tank.
/ Fuel cans #31
Like most regulations the ones for which containers are legal to be filled with flammable/combustible liquids come from folks who do not have any common sense and use things like glass gallon jugs to carry gasoline. Now that almost all fuel stations do not have pump attendants I'm sure we will eventually see some cases pop up where someone did something stupid and blew themselves or others up and a whole another round of regulations will come to be.
/ Fuel cans #32
Like the no-spill diesel fuel containers. Even my wife can fuel the little tractor but doesn’t like to. The bad part was holding the button down. 5gallons took 2-3 minutes to drain. Added these vents.
ZOOYL Gas Can Vent Caps Retrofit Kit 6 Packs, Enhances Flow for Faster Refills, Universal Fuel Tank and Gas Can Replacement Vent Valve Made of Durable Stainless Steel with Attached Silicone Rubber Cap https://www.amazon.com/dp/B08VH2ZL1...abc_T7P0EXR2HVQBDW8NV2R8?_encoding=UTF8&psc=1
Also retrofitted some jugs for the bigger tractor.
Had a bulk tank for awhile when farming more. Maintenance, filters, additives, draining, algae all cost time and money too. Use 80-100 gallons per year lately. Went back to jugs. Maybe switch to 55gallon drums? Hoisting jugs is kind of a barometer to keep tractoring.
What ever bulk tank you use, a pressure/vacuum vent is necessary for storing fuel around here. Keeps your fuel dryer. Surprised how many tanks I see with just a rain drip vent.
/ Fuel cans #33
I found this pump at my John Deere dealership. It has four AA battery’s and a auto shut off nozzle that works great. There are one on button and off button that you just push no hold. I put this can on my Kubota tractor floor board and then attach the hose with a spring loaded clamp Into the tank. This unit pumps real fast with no leaks any were. It comes with extra fuel can fittings to fit a verity of fuel cans. I have a tidy tank i used to use but is to much trouble to load and unload etc. I just take a couple of Gerry cans and fill them so i always have fresh fuel plus no trouble to switch to winter fuel as well.
I Am getting up in age and this works great for me and I would not go to anything else and I have had them all This one works !!!
/ Fuel cans #34
/ Fuel cans #35
They’re technically sportsman cans not fuel containers that’s how they avoid that BS. Those are the only 5 gallon jugs I use. Aside from not being saddled with bs they have the best spout of anything I’ve tried even the older cans. They can work with the can 90 degrees or completely upside down which not many other cans can do that and they have a cap to keep trash and water out of the can. They also seal up pretty well to minimize spills even if they turn over. I’ve tried some of the modern production jerry cabs and they’re not half bad but I prefer plastic cans over metal.
/ Fuel cans #36
I’m not a fan of having to keep up with separate funnels that still need to be cleaned. And that only works for horizontal fuel caps. My skid steer, mini x and lawnmower, along with most vehicles have vertical fill holes. Trying to keep a funnel held upright and hold a 5 gallon can by yourself doesn’t work well.
/ Fuel cans #37
No batteries, low cost, no damage to the hood and still use the old fuel cans.
Just need to know when to pull the hose from the supply tank.
/ Fuel cans #38
/ Fuel cans #39
Still using 5 gallon jugs, but in the Spring I am going with a 50 gallon square tank and a 12v pump. I will mount it so I can load it and unload it with forks for a run for fuel. I've been using 60 to 75 gallons a year so 3 trips in two years will do me. I am considering stepping up to the 100 gallon version, it's just $20 more, but fuel isn't all that far away.
/ Fuel cans #40
I use these kind of containers and have about 8 of them. We keep them in a shed well away from the barn and house.
For fill ups, the big yellow JD tractor is easy. The whole tractor is built to be used. The tank is down low, it has a huge lockable tank filler opening, a place to put the lid, and a platform for resting 5 gallon jugs on while you fill it
I like our Kubota a lot. But like so much on the tractor, the filling of the fuel was designed by someone who never had done that job. So I can either stand on the front tire and hoist one of these up to chest level.... and hold it there while it empties - or just drive down to the fuel shed and use our battery powered transfer pump.
1979 AM General 6X6 Truck (A65563)
1979 AM General...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
