XC drag build
/ XC drag build #41
Smooth Move XC
Smooth Runnin
Groomzilla
Gladiator Groomer
Ghost Groomer
/ XC drag build
I was at my real job for the morning, then spent the rest of the day, until 8 this evening in the school shop making parts. I am getting to old for those hours! o_O I took some pics for you guys but it will take some time for me to process them.
/ XC drag build
OK here is some work I got done yesterday and for you machine shop connoisseurs, I'll include pics of the machines used. This 3/8 plate will hold all cutting frames on, so it will see a great deal of stress. On the 4" channel, I drew the profile of the pan. The little plates bolted on its top are 3" tall and will be the pivot points and welded onto the ends of the 3" channel that create the cutting frames. The 1 and 1/4 hole on the side of the plate is a tow location if you need to tow this implement out backwards. This plate will see more trimming before its segment welded on.
Another pic of this setup.
Now making those little brackets you see that will be welded on each side. They are 3 x 3 x 1/4 angle but they will be trimmed down.
Punching out .5 holes for the pivot bolts.
Drilling them out, one size larger than .5. (I can't recall the drill size)
Kerfing the holes with a 90 degree chamfer.
Not shown is the cutting off and rounded them off. All edges were sanded off.
/ XC drag build #44
"Dragon"
Anyone using the trail would be following Dragon Tracks...
Users would be reminded to stay on the Dragon's Trail...
When on a Dragon Trail, be on the lookout for a Dragon. (They sound just like a snow machine!)
An intersection would be a Dragon Crossing.
Dragon sightings could be awarded...
If you breakdown, hopefully somebody starts Dragon hunting...
/ XC drag build
Smooth Move XC
Smooth Runnin
Groomzilla
Gladiator Groomer
Ghost Groomer
Groomzilla seems to be the winner polling with our pals.. :cool: Thanks for the idea's!
I'm heading into the shop on Wednesday and be there all day, like 12 hours. Picked up the pans over the weekend. They were left outside with a bill taped to them. This is the UP!
Sorry for the poor photo here but the top is on the right side. I should have put there bottom section flat with the truck bed.
/ XC drag build
Work done on the Groomzilla project.
This shows the anchor for the cutting teeth and the bracket that will be welded to 3" channels. Its all made from 3/8 plate. There will be two on the bracket held by the same .5 bolt.
The pan got its reinforcement flat welded to it. The pan is 14 gauge and the flat is 3/16 x 1.5". Any guesses why I would plug weld it on?
This shows how the pan will be welded onto the 4" main frame channel.
Here is the anchor tacked on to the frame!
/ XC drag build #47
Looks great.
Looks like you're making some good progress.
/ XC drag build
Much work was done to Groomzilla frame members this week.
Top photos are holes drilled to hold flexible wings on. The channels open side is the outside of the implement.
Holes were also drilled for skags. With cutting frame anchor actually welded on!!!
Here you can see how the 3" channels will be attached to hold the cutting frames on.
Any questions or comments? This is the 4th drag I've built or modified to improved on over the past X years.
/ XC drag build
Work done this week. This is the mian frame and I cut off the ends to give them gradual roundness. I used a torch to cut these over the years but this time, I tried a battery powered band hand held bandsaw. Worked fine!
After its shoe base and hitch attachment was welded on. The base will be where the plastic skis are bolted to..
My O35 wire welder settings.
One side is done!
/ XC drag build #50
Very Nice
/ XC drag build
I'm awaiting for a pan from Yellowstone track systems. I already have one here but need another for the 2nd drag This is what they look like and run about $1600 each.
/ XC drag build #52
i don't wanna sound like a geezer but.....i will.
i took up x country skiing in 1970. it was just becoming a thing. wisconsin has long winters!
looking at the trails you maintain and the equipment they have now, what a difference, looks like they made some progress in 50 years.
Our skis were wooden that you had to wax and the "boots" were like very thin leather slippers with 3 little holes in the front of the sole that located on 3 tiny pins.
either the boots came off your feet or they twisted around so bad the boot became a turnaquette (stumped spell check with that one)
trails? the first guy in line made the trails, like a bull dozer. kinda like a flock of geese, every so often it's your turn to lead!
wanna get some exercise? go x country skiing!
/ XC drag build
Work done over the past week. Extra 1/4" plates added to the hitch attachment mounts. Why would we do that?
How the hitch will attach. Th holes in the ski plate are for mounting plastic skis. You can't see the rearward most one. These hdpe skis will be about 6" x 21" in size and what the front of the implement rides on.
/ XC drag build #54
We have 20-40cm of snow coming. Grounds not frozen but I’m sure some die hards will want some grooming done.
nice work Arly!
/ XC drag build
We have 20-40cm of snow coming. Grounds not frozen but I’m sure some die hards will want some grooming done. nice work Arly!
Thanks T chicken. We've been receiving skiffs of snow here but not enough to worry about. I just got my new snow tires ordered! I'll get some photos from this weeks drag work posted soon.
/ XC drag build
These 1/4" plates were added this past week. They hold the 2x2 tube across the rear that the pans are mounted to. These allow operators to adjust the position of the tracks across the implements back.
Yes, if I did this again, I'd have made them from a single .250 plate and reinforced the appropriate area's and cut them with a cnc plasma torch.
This shows the plates and how I cut the square holes out
After they were welded on and the position of the 2x2.
What this tube looks like on YTS implements.
/ XC drag build #57
Groovy!
/ XC drag build #58
Good work Arly!
You might think about making a stencil to use wit the plasma cutter. It's a thin plate with a cutout, say a C shape like you cut out, dimensioned so it allows for the width of the cutter nozzle. Just clamp it in place and run the torch around the edges for a perfect cut.
I have a set of these, which are very handy.
https://www.amazon.com/Plasma-Stencil-Square-Cutter-Guide/dp/B01FL1BIEY/ref=sr_1_4?crid=3VLMTZUOFLJ9K&keywords=plasma+cutter+stencils&qid=1636857720&sprefix=plasma+cutter+stencils,aps,187&sr=8-4
https://www.amazon.com/Plasma-Stencil-Circle-Cutter-Guide/dp/B00OCH0JMQ/ref=sr_1_2?crid=3VLMTZUOFLJ9K&keywords=plasma+cutter+stencils&qid=1636857780&sprefix=plasma+cutter+stencils,aps,187&sr=8-2
/ XC drag build
Good work Arly!
Thanks Dennis, but I'm not the cnc torch operator nor do I own it. The fellow who operates it (its owned by the school) is struggling to get it to do this and that.
/ XC drag build #60
Great build. I would love to see a video on the complete operation of that when it is all done, looks complicated lol, but very professional. My buddy and I have been grooming the local ski trails around here for over 15 years now. Our DIY equipment is no where as fancy as yours, but it works. I built all of it myself, roller, drag and track setter. We dont use the roller anymore for the big snow falls, we just drive around with our sleds first to pack it like you mentioned in one of your previuos posts. I built everything light so it could be pulled with a standard snowmobile but now we use a quad with tracks. Just last year we mounted the track setter to the drag so we can do one pass grooming which saves a ton of time. We just rely on the weight of the track setter to cut the tracks but i really like the idea of using jack to add pressure to a lighter smaller track setter. Our drag is extremley simple and is just built out of 3/6 x 2 angle and doesn't have a pan on the back to pack or corrigate the the final result but I would love to add that. I wll be following this to see the final result.
Guardian Propane Generator (A61567)
Guardian Propane...
2008 Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A61569)
2008 Regal 2565...
1820 (A62130)
1820 (A62130)
2010 Hardi Navigator 3000 Pull Type Sprayer (A63116)
2010 Hardi...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59908)
2016 INTERNATIONAL...
