Clamp On Ripper Tooth?
/ Clamp On Ripper Tooth? #21
My welder/fabricator made me a bolt on bracket for a tooth from a box blade that is bolted to the middle of my bucket on my BH92. I only wanted it to dig out rocks so I don't make a mess with the the 18" bucket. Works fine.
/ Clamp On Ripper Tooth? #22
Got a picture? This is the direction I think sounds best. I was thinking that bracket to bolt on over the backhoe bucket teeth would work well.
Yeah, that's what I'm looking for, but I don't have a welder/fabricator at my disposal, so I have to work with what I have.
/ Clamp On Ripper Tooth? #24
I once needed to clear a bunch of saplings that had taken over a gravel drive.
My solution was to DIY a clamp on oversized tooth for my CUT bucket.
That worked like a charm!
The saplings popped out nicely and clean leaving all the roadbed in place.
A simple back grading with the FEL bucket slightly tilted had that drive looking like new.
/ Clamp On Ripper Tooth? #25
Get a ripper tooth with a quick attach, from either Bro-Tek, or bxpanded.com. I have Bro-Tek one, and I can switch buckets in a matter of seconds
I wouldn't buy anything from bxpanded right now. They're not shipping product.
/ Clamp On Ripper Tooth? #26
Sorry, no picture. Haven't had to use it too many times, but works great. Bought the tooth online, it's mounted in the middle between the teeth, the bottom has a slot that slides over the top and bottom of the bucket and then a longer tab is on the inside of the bucket with a bolt through it.
/ Clamp On Ripper Tooth? #27
Forgot to mention that he also made the tooth length adjustable too.
/ Clamp On Ripper Tooth? #29
Too bad. I bought a lot of stuff from them over the years.
Yup. I put an order in nearly ten weeks ago and was told 4-6 weeks lead time (which is what their website still says). I checked with them at 6 weeks and was told mid-November. I checked the other day and now it's "towards the end of the month". I've already been billed for it too :rolleyes:
/ Clamp On Ripper Tooth? #30
So I ordered a piranha tooth bar on 11/3 and it shipped already on 11/9. I might have gotten lucky because it was for a BX and they probably stock or build a few of those ahead of time....
/ Clamp On Ripper Tooth? #31
Just got shipping confirmation of my ripper tooth from BXpanded. Let’s hope it was worth the wait!
2014 Chevrolet Express Shuttle Bus (A61573)
2014 Chevrolet...
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
1999 Bell B25C 6x6 25 Ton Articulated Dump Truck (A61572)
1999 Bell B25C 6x6...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A64280)
(INOP) 2013 MACK...
