BB60 vs EA Rotary cutter
/ BB60 vs EA Rotary cutter #1
tsperry88
Kubota B7610
I have an opportunity to pick up an excellent condition Woods BB60 for $1400. The EA 60" cutter I had planned on buying is more $$. Anybody got knowledge that will push me one way or the other? The Woods is green and my tractor is orange, is one downsidešŸ˜‰
/ BB60 vs EA Rotary cutter #2
I bought a used BB72 for $800, but it had output shaft slop and seal out. New bearings and seals fixed it. I think it was ran with out gear lube.
I expected the Woods quick change blade system. It came with standard pins and nuts. That was the only down side for me. I was looking for BB720 in the $2K range when I found this one.
/ BB60 vs EA Rotary cutter #3
I paid $1900 for a Yanmar 72ā€ rotary cutter last spring (YRC720 I think is the model #). It’s almost exactly the same as the BB 72ā€ cutter…..except black. Nice mower and about $500 less than the orange one. Plus I like the way black and green look togetheršŸ˜‰.
/ BB60 vs EA Rotary cutter #4
Which is heavier, gearbox HP and cutting capability? Those are the three things I look at. Slip joint vs shear bolt is another one.
/ BB60 vs EA Rotary cutter #5
I have an ea 60. I can’t speak for the bb but the ea is a beast. My particular cutter was damaged in shipping and when I contacted ea the parts went out the same day no question asked and they credited me for my time to install the new parts I would recommend ea to anyone who wants a quality American made product
/ BB60 vs EA Rotary cutter #7
A two digit Brush Bull won't be a beast. It's the lightest duty of the series.
The BB is light duty. If you want heavy duty get a Brown 415 but it will be just under $3000 with chain guards and back ordered until Spring
/ BB60 vs EA Rotary cutter #9
The woods is 748 pounds and 65hp gearbox.
The EA is 665 pounds and 45hp gearbox.
You can get parts for a woods just about everywhere. Can the same be said for the EA?
If you are looking at lighter duty cutters it's pointless to mention the handful for $3000 and 1500 pound heavy duty cutters designed to run over 4" stuff. So we won't go there.
/ BB60 vs EA Rotary cutter #10
Also worth asking....what tractor are you running this behind?
/ BB60 vs EA Rotary cutter #11
I doubt you will be disappointed with either. I was in the same shape as you a couple years ago. I found an almost new Woods at a discount and went with it. It is my7th cutter and I would say it is the best.
My tractor is small LX2610. I have owned a few tractors, but never a cutter. The Woods is still listed, but I offered $1300 and the guy wouldn't budge. I would likely never try to cut anything larger than a 1" sapling. Larger than that I would pull out. I'm going to take a skid steer and brush cutter through my back 4 acres of woods, and keep thinned put with whatever cutter I buy.
/ BB60 vs EA Rotary cutter #13
He has got a fair price on it if it is indeed excellent condition. You are either gonna pay more for a new cutter, or less for something in worse shape.
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
90in. Work Bench (A65640)
90in. Work Bench...
Calf Creep Feed Hut (A66408)
Calf Creep Feed...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
