Complete Turf Care
- Joined
- Mar 31, 2013
- Messages
- 2,458
- Location
- South Louisiana
- Tractor
- 2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
Okay. I've found the threaded rod. I think mine is slightly different than the one you've shown because mine is a M4700, instead of an MX4700. However, I was able to adjust it and I can easily tell a difference in how things react when I move the levers.
I didn't have a 100lb weight so I tried standing on the lower links. I'm about 200 lbs. I'll do some more adjusting when I have more time. I could not unscrew the upper part of the threaded rod, so I removed the cotter pin and adjusted only the lower part.
It looks like where the lower part of the rod connects, may have gotten bent, which would throw it out of adjustment.
