New CK3510SE-HC
/ New CK3510SE-HC #41
The dealer distance was really the only thing I was worried about when picking kioti. I had a bit of a scare last week, came out the day after breaking in the box blade and there was a puddle under the front axle. I felt around under it and couldn't find anywhere wet, checked all the fluids and everything was ok. After using it that day I cleaned everything off and parked in a different spot, next day a small puddle but this time I saw from where. Gave all the hose clamps that I could get to a turn and it seems to be all good now, coolant is on the mark.
With cameras flipping images I'm not sure what side that is, but double check the actual overflow cap. Mine was not on all the way (engine side not down fully) and allowed coolant to spill out. It was marked as inspected, but is really hard to fully seat.
/ New CK3510SE-HC
That is the "driver" side, looking up from the front axle by where the block heater is. The overflow bottle is on the other side, and as far as I can tell the overflow tube as well.
I couldn't get a driver on that smaller hose that runs to what I would guess is the cab heater, the orientation it is installed in puts the head of the clamp directly behind the exhaust mount. I've put about 6 hours on it since tightening them all and haven't seen any more leaks, the level is easy enough to check when I check the oil each time to be sure.
/ New CK3510SE-HC #43
bekenney, no my codes were:
dtc
F 05
2
End
and
dtc
F 05
8
End
My codes where much shorter. The dealer wanted me to replace the fuel filter and they are sending me one. They also called and told me one of the codes indicates the fuel filter is clogged (makes no sense on a tractor with less that 2 hours). The other code indicates low pressure at the common rail. They had me check the sensor and the wiring. They think the sensor may be dead.
In the meantime, I went about checking everything fuel related and I found that the line coupler from the fuel pump to the fuel heater is not a good connection but there was no indication of leaks. I popped this line off (it is a quick connect and that is why it is loose feeling) to make sure it was okay, bled out some fuel, then reconnected. Amazingly, the tractor ran after doing the bleed from that line. I did not notice any air. However, doing more online research, I found that it is a common issue for diesel engines to get air into the cooling coil system. It is not an easy fix to bleed them. I just got lucky. I ran the tractor for about 20 minutes moving dirt around in my back yard. I let it cool down for three hours. I had some trouble getting it running again, thought the issue was back and I had just been temporarily lucky, but after about 10 minutes fighting the tractor, it stayed on and ran nice. I did more dirt moving. Letting it sit overnight, the next day I took it out for a neighborhood joy ride. I drove it down the street about one mile loop, using all three gears (L M H), and driving in reverse a few times for over 100meters since it was dying any time I even tried to go in reverse. Everything was great. I did not retry anything today as I had other projects but I am hoping it will run great. Oh, I did do one heavy lift with the FEL just to load up the tractor and make sure it would not die. I lifted a backhoe from my TYM tractor and drug it around the yard. I could not lift it totally without lifting my rear wheels but it was enough weight and load to test the tractor.
My guess is that on the 1100 mile delivery trip the rocking and rolling allowed air to get to the wrong places. If there are issues after I run the tractor again tomorrow or Saturday, I will let you know.
Sorry my codes where not the same to help you out but that air lock issue with diesels seems to be very common. Good luck. (Now I am curious so I will go run the tractor.... )
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2012 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A61568)
2012 Chevrolet...
2015 Ford Escape SVU (A61569)
2015 Ford Escape...
2021 CATERPILLAR 299D3 SKID STEER (A62129)
2021 CATERPILLAR...
2025 SDLANCH SDLC1220 High End Carport (A60352)
2025 SDLANCH...
