Not Charging
/ Not Charging #81
Pretty straight forward still on a YM 2000. My dash light would flicker!! Chased that for months and finally stumbled into it. Loose bad connection on my fuse panel. More corroded than I would have thought. That was more of the problem. Still ? how I found it!!...... Drove me nuts... Here is the 2000 dia. I just had out for anyone who may need it!!!!
Your electrical schematics is of the YM240 era.
I dug out all I had on the YM 4-digit 2000 machines.
  • YM2000X-ELECTRICAL SCHMATICS.pdf
/ Not Charging
Here are pics of mine.
/ Not Charging #83
Your as bad as me on keeping things in order!! Ooops wrong thread :unsure: That's what I'm expecting to find on the filter if that..........
/ Not Charging
I was about to say, wrong thread , just discovered this myself when I came back to see if there were any replies. Those interested on the thread these belong too click here Check your hydraulic screen/filter
/ Not Charging #85
Read this thread because I have a no charging situation on the YM 2020D. This alternator does not look like what you guys have. See picture. Hoye says its a dynamo. As I trouble shoot this, should I be getting DC volts out of the two wires from the alternator/Dynamo or AC? I checked today on DC and had no voltage. Its a $150 part so want to be very sure before I purchase.
/ Not Charging #86
/ Not Charging
I honestly have no idea. I thought my alternator was good at one point cause of a voltage reading I got at the unit. Not sure if I was reading the wrong type of volts but for whatever reason the volts were not getting to my VR and the. To the battery.
/ Not Charging #88
When you think about it, there is absolutely no reason why one single design of alternator with an integral regulator wouldn't work for 99+% of all cars, trucks, and tractors in the world. Today, most alternators have the regulator built in. They spin, and generate the proper voltage to charge a lead acid 12 volt battery. And that's all they do. All an alternator really has to do is physically fit, which is easy because most alternators are run by a belt pulley and at close enough to the same RPM.
The only thing that alternators do is to charge a 12 volt lead/acid battery - and regardless of application those all charge at very close to the same rate. Batteries have little or nothing to do with make or model of what they are installed into. Batteries vary in size and position of the terminals, but we know that they are all basically interchangeable. Alternators could be and can be just as interchangeable too.
rScotty
/ Not Charging #89
Dynamos put out ac voltage that will vary depending of rpm.
/ Not Charging #90
Looking at the above pictures, that looks to me to be an alternator, not a dynamo. I do not know this set up, but, if it was mine I would set my volt meter to AC, then put the positive lead to one of the two output wires and the other to earth [ground]. Take a reading and then check the other output wire the same way. At a guess, one might be larger than the other. Now I'm still guessing, but the one with the largest output probably goes direct to the battery. The other, I'm still guessing, is from a voltage regulator somewhere on the tractor, that might be next to a rectifier. Whilst I have my multi tester in my hand, without the engine running, I would set the meter to resistance and check there is a good reading between the alternator and the tractor chassis. Lots of guessing here but I hope it helps.
/ Not Charging #91
There's a thread on here somewhere about that 'dynamo'.
To summarize, early ones had rectifiers on the back but by the time of your YM2020 the rectifiers were external. Output of this dynamo is AC, so test for AC output, and also for continuity (a few ohms resistance) between its two wires to verify that the coils inside are intact.
That dynamo is universal. It is used by Yanmar, Kubota, and a lot of lawn-care equipment in the under 30hp category.
Nearly always its matching regulator is the problem. If your regulator has a 6-wire connector, then any regulator on Ebay that looks the same and has wires ending with the 6-wire connector - will be the same generic regulator.
This YM186 wiring diagram shows that its dynamo doesn't use chassis ground. I expect your 2020 is wired the same.
Does anyone have a link to the prior thread that discussed troubleshooting this dynamo/regulator combination?
/ Not Charging #92
Why ;not just go the the auto parts store
and get a cheap life time warranty with it
willy
/ Not Charging #93
willy
Got the cross reference p/n to an autoparts store brand. That's the clue we need to do just that.
Yanmar liked to used Datsun parts from the late 60s and early 70s. Parts that were prior to Nissan acquiring Datsun.
/ Not Charging #94
The larger alternators on the YM's with two mounting tabs, are generic automotive from the same era, 73 Datsun or similar. That and the matching regulator are cheap at Autozone. Just specifiy the non air-conditoner version for a perfect fit. The higher output A/C one is fatter and needs a different mounting.
But this pancake 'dynamo' with just one mounting tab is unique to small Japanese tractors and similar (maybe battery-start generator sets?). I doubt Autozone has them. Ebay is where I've seen the best prices for this and its regulator.
____________________
Trivia: Datsun IS Nissan. Legend: Some other firm owned a trademark named Nissan in the US.
Per the legend Nissan was all ready to ship over their first cars when they discovered this.
Strategy meeting "What will we do? We need a new name in just a couple of days!" Somebody replied "That Soon?"
"That's it!!!" the CEO replied. :p
/ Not Charging
Should it be "Dat soon"?
/ Not Charging #97
I would go for the single wire alternator
should be less than $50
willy
/ Not Charging #99
The larger alternators on the YM's with two mounting tabs, are generic automotive from the same era, 73 Datsun or similar. That and the matching regulator are cheap at Autozone. Just specify the non air-conditioner version for a perfect fit. The higher output A/C one is fatter and needs a different mounting.
So, alternators without the AC option. Nice. ;) I like having a warranty on things like this. Yet, I plan on getting a VR as well, the 'new' style. Even though mine is re-ferb UTDA by Fredricks, the old style, yet new part was used. The old design are prone to over heating.
My Ym2610 is the 35A alternator. Wish there was a 45 or 60A version. ;)
/ Not Charging #100
Recalling back and checking into my Chrg. light problem there was several ways to setup these Yanmars. The Org. YM series,Rice patty tractors was hard on the Elec. Sys.. When digging in deep of my dash and Fuse panel I found out this to be true. Both VR. Old Mech. style still up in the Dash and the New SS attached around the Stering column. Found the bad connecton and then curiousity had me check the old one. Works fine!! So now I have both and then seeing my Alt. is actually 12V 35Amp. Which is Huge for my needs. No wonder My old battery lasted so long. Only 550cca. New 700cca now. Cold start is Minimal for the oil light to come on. I was actually shocked looking at the parts book. My Alt. is AL-1235 35Amp. and seen the next common Alt. is a AL-1215. It was much smaller at only 15Amp. and on the 2020 that was just mentioned is listed for it. That much smaller seemed odd.
