lightning rods
/ lightning rods #41
I used a friend's rotohammer & it worked well on all dozen 8' rods I instslled even in out hard clay. You wantvas much contact between the dirt & rod as possible. Driving the rod in like a nail gives optimal contact. Digging a hole or using a water jet especially creates a hole bigger than the rod. It will sit loose in the hole & give you a much worse connection to ground. The higher the resistance to ground, the higher the likelihood that the lightning will find an alternate path to ground. Murphys law says that other path will be something that will melt, catch fire, or otherwise Bevan expensive repair.
The rod doesn't stay loose in the hole for very long. It is a wet job, but gets done quick and in the end the result is the same. Another plus is not having to extract the rod when you get it half way in and hit a rock that says you shall not pass.
/ lightning rods #42
When I built my yard we trenched between all the buildings and the pole. Instead of rods at each building, there was a heavy copper ground wire buried in the trench alongside the service cable. They all tie together back at the pole and into the grounding grid of the pole. It's a hell of a lot more contact than you'd get with any reasonable number of rods....
/ lightning rods #43
Just like any other compaction job, it takes years for dirt to settle. If you aren't compacting in 6" lifts it's not compacted. Try getting a fence post to stay tight in a hole if you don't massive tamp in the backfill every few inches. A ground rod is even worse as you aren't getting any backfill or compaction a fraction of the way down that hole.
You need maximum surface area contact between that dirt & rod. If you put the rod in a hole even a little bit bigger than the rod it will only make intermittent contact with dirt. You'll end up with a high resistance ground.
I had a friend who was a sparky in the air force. In some bases in the desert they would excavate around the buildings & weld 4x8 sheets of copper plate together all the wayvariund the building then backfill & compact properly. The dry sand ground was so poor of a conductor they needed to go that far to get good low resistance conductivity to ground.
There are specialty multimeter type devices you can use use to verify how well your ground system is actually working. They usually show bored holes not working well unless the ground is super conductive & moist year round.
/ lightning rods #44
Actually, electricity mostly flows along the surface of the wires, which is why the conductors for lighting systems are multi-strand braided wires instead of one big wire. More surface area means more conductive capacity, which is why those wires don't melt. (This is even more pronounced at higher frequencies.)
Wrong. If anything stranded wire has a greater resistance than same AWG in solid. Look up AWG wire current capacity tables. This site says stranded has lower current carrying capacity but most codes do not distinguish between stranded and solid: Stranded Wire vs Solid Wire in Electrical Applications
Current flows in fields at and near the surface of conductors. Bundled conductors aggregate the effective diameter not the areas. High power utility lines have steel core for strength surrounded by aluminum for conductivity. Note really high voltage systems bundle 3 conductors several feet apart as one conductor to increase the diameter of the electric field. Those 3 spaced apart have less total losses than 3 individual conductors.
/ lightning rods #45
Is not just a matter of contact or depth in the ground. In some situations the best "ground" is to be had laying a long bare wire on top of the dirt. That works everywhere but can be a nuisance.
/ lightning rods #47
The burying the bare wire in the trench eliminates that nuisance
/ lightning rods #48
I'm under the impression that very dry ground is a poor conductor and therefore a poor electrical ground (thus why electric fences don't work well when the ground gets really dry unless you're expecting the fence to zap between the hot wire and part of the fence instead of the ground).
My ground here is bone dry two feet down in the summer, but when you pound a rod down deeper you start getting a decent year-round ground.
I guess the ground ring or ground-in-a-trench works because there's just so much more ground contact that it makes up for the higher resistivity of the potentially drier soil?
Interesting related article: https://www.ecmweb.com/content/article/20892049/achieving-an-acceptable-ground-in-poor-soil
/ lightning rods #49
What you’re talking about is “skin effect”. It’s only a thing with AC currents. With DC currents, the current will be uniformly distributed across the cross section of the conductor. With 60 hz AC currents, skin depth is about 8.5mm.
One has to be careful with conductor ampacity charts if you’re using one for the other, or if you have 400hz as is common on air planes.
/ lightning rods #50
One does not install lighting rods to conduct direct strikes to the ground. Lightning rods work by dissipating static electricity. Stranded wires are only used for the convenience of the installers. Solid wires are more reliable.
/ lightning rods #51
Where I built the previous house was hit by lightening (and burnt) which supposedly never strikes twice so I'm OK.
Or am I?
OK, I have a TV tower and I did a good job of grounding it plus my hydro grounding is all up to par with 2 9 ft rods completely driven in.
Fingers are always crossed if that helps.
I've seen it strike twice I didn't stay to see if it happened a third or more times. It hit a pipe in a pond about 75 feet from me. Made my guts shake.
/ lightning rods #52
Correct. Of you have a 50 ohm resistor, you get 50 ohms of resistance. If you have 2 50 ohm resistors in parallel, you get 25 ohms of resistance. So basically you can make up for poor earth ground by increasing the surface area of the ground interface.
Generally you don't want ground rods any closer to each other than their length. So generally 8-10' or further apart. The usable area a ground rod can conduct to is kind of a cone. If rods are to close together they are kind of overlapping & decreased in effectiveness.
Adding bentonite around ground rods helps hold moisture & improves conductivity. There are some other things you can use to increase ground conductivity, but some are a bit toxic (salt).
/ lightning rods #53
It’s the grounding that dissipates static electricity.
How does a pointed metal rod sticking up in the air at the highest point dissipate static on the building underneath it?
Being directly grounded, lightning rods definitely decrease the distance of the “ground” to the cloud. Some would argue that this increases the chance of a strike, but lessons the damage.
/ lightning rods #54
I been close twice, both times on the golf course.
1st time with niece and nephew. hit a tree 30 yards away, all i remember is this huge explosion and then the sky full of debris, pine bark i guess.
2nd time, on pay phone in golf course clubhouse working. i saw a big ball of light and some guy asking me if i'm ok? I guess a big ball of light came out of the phone i was holding?
/ lightning rods #55
That’s what you get for poking electrical sockets with a knife…..
NOW YOUR A CONDUIT FOR LIGHTNING
/ lightning rods #56
On my place, we built our stick house. We knew that there were lightning hits all around us before that point. Saw evidence on the trees as well as the nearby noise level. Specified a lightning rod system on the house and for 15 years it has worked perfectly. [[ Such as system is designed to dissipate the electrical energy before the charge builds to a point where a strike occurs. Learned this in one of my engineering courses.]]
Next, we built a very large metal barn with concrete floor. It was not 3 months after building it that I found a big piece of sparred concrete around one of the frame columns. I knew it had to be due to a lightning hit. Nothing had been planned or implemented to deal with lightning, so I bought my own version of lightning protection - ground rods, and roof spikes. I planned to connect both to the steel frame so the frame was the conductor between. Remember that most homes are wood, so copper wiring must be added to their system. No so with a steel frame. I inserted 3 ground rods around the perimeter and wired them directly to the nearby frame. I still have the roof spikes; they were never installed. Turns out that is all that this building needed - never had any further issues in 10 years. What was missing was a connection between the metal and the ground - the concrete was a poor conductor, so that when the first lightning hit occurred, the concrete between steel and ground heated to the point that moisture in the concrete flashed - creating the sparring.
Buzzards - occasionally I still hear their toenails tap-tap-tapping on the steel roof. If I let out a few loud "barks", most times they will leave.
[[ ]] This truth is seldom shared. - - The mechanism? : High electrical potential at a surface that has great inflection. The point of a lightening rod is such a surface. For lightening the point is best blunted a little. The "point" promotes corona discharge, reducing very local earth/sky electrical differential. The lightening is thus a little less likely to strike there.
/ lightning rods #57
Lightening is a high frequency event. Skin effect and inductance are important. Strap copper instead of wire is about the best you can do to optimize so that its a low impedance path to a "bolt".
/ lightning rods #58
God doesn't like golf.
/ lightning rods #59
You clearly don't understand.
The pointed rod really does attract the local static charge. Just as scooting your stocking feet on carpet then spark jumps between your fingertip to the doorknob.
There is no way skinny lightning rods will withstand a direct strike. However if one disconnects the grounding wire leaving a gap up to 1" then watches when the wind blows one would see arcing across the gap. Perhaps you would call those "lightning strikes"? Not really coming from the sky any more than the spark from your finger.
By discharging the static on one's building one makes adjacent trees and structures more attractive than one's protected building. The difference in electric potential is greater, until there is sufficient voltage to break down the insulation of the distance between earth and sky. A bit of water in the air reduces the resistance.
Something we have been touching on but deserves much more understanding is "ground". Ground is not a firm fixed absolute. Ground potential (that is Electrical Engineering for "voltage") in one place is different than in other places.
/ lightning rods #60
[[There is no way skinny lightning rods will withstand a direct strike.]]
[[ ]] Careful. Its a very short event. The fractional second fusing current of 3/4" copper is bound to be extremely high - perhaps ~the Meg-Amp range.
NEW Wolverine GB-11-72W Skid Steer Grapple Bucket (A62679)
NEW Wolverine...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
Lot of (15) Hedge / Black Locust Posts (A66408)
Lot of (15) Hedge...
2000 Hino (A64194)
2000 Hino (A64194)
