shooterdon
Super Member
- Joined
- Nov 24, 2012
- Messages
- 5,513
- Tractor
- 2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
Never heard of a Rat Guard. Rat walls are a good idea to keep burrowing critters out.
I built a 30x40 for my brother. He wanted 10' overhead doors at each end. After it was built, he then had time to plan floor drains and fixtures in the floor and then poured the floor. Good Luck LarryI'll most likely build it and install the roof and 3 walls then do concrete. That leaves the whole front wall open to work in.
BTW $150 per yard for concrete.![]()
LoL I used wheel barrows.I did my floor 11 months after the building was up. I had to pay for a pump as a truck couldn’t get into the building (only 10x10 doors), but that was it. Morton does a great building. Nothing touches the ground that is wood, all concert (posts, rat board, everything).
Wow,....That seems as though you got a great price!I bought a pole barn kit in Nov 2019 for a 30x40x12 pole barn for $13K. If you can do it for $14K, jump at it. You won't regret getting it built sooner rather than later. I put up the frame and put on the roof and then did the concrete floor. Finished with the walls.
That's a nice looking building, I went to your post and checked it out.I bought a pole barn kit in Nov 2019 for a 30x40x12 pole barn for $13K. If you can do it for $14K, jump at it. You won't regret getting it built sooner rather than later. I put up the frame and put on the roof and then did the concrete floor. Finished with the walls.
Not sure what you mean by "far superior to conventional pole barns".If the OP isn't aware, there is a very good YouTube channel that has a ton of videos on building "pole barns". He uses Post & Beam construction, and has convinced me that it far superior to building conventional pole barn procedures.
Also, whenever you build something from a kit, you will run into unique situations on your own site. And you will likely have to adapt components of the kit to fit your situation. That's why I always use a local lumber yard for my supplies. And often times they are less expensive and have good service.
Anyway...here's the link to the YT videos if you care to check them out:
Is your barn heated full time? If not I would think the floor would crack from the freeze-thaw cycle.With a pole barn, the poles themselves are the actual footings - they typically get placed 3 to 4 feet down, atop concrete pucks or encased in some concrete. This is below the frost line and is what structurally holds the whole building up. You just then toss a simple slab down inside the skirt boards, no footings needed. On my 30x36 pole barn, I did dig a 2' narrow rat wall around the perimeter though.
Have a neighbor down the road whose barn was built in the 50's-60's (long enough ago that the metal is actually aluminum) with a floor poured after it was built. Like yours, it has some hairline cracks but it otherwise fine. No heaves or whatnot.We live in Northern indiana. There is a barn on our property with a concrete floor. Footings are as described, the poles being 4 feet down and sitting on a concrete "biscuit". The floor is just poured. It has been there for at least 20 years. There are a couple cracks in it, but nothing that would require it to be redone. You could still roll something on small casters over it with no troubles.
Very nice!I put up a 36x50x12 with (2) 10x25 porches a couple years ago. Most of the floor is packed 1" crusher run stone, except for one of the porches and a 12x30 ft interior area under a loft that includes an enclosed and heated 12x20 ft woodshop and an open 12x10 ft metal shop, which are concrete.
I made the loft and interior shops using American chestnut lumber (hand hewn posts and beams) reclaimed from my great great grandads 1883 barn that was previously on the site.
I love the concrete floors in the shops and porch but I also like the stone floor in the rest of the barn. It is nice not to have to worry about tractors dropping a little oil or my boat leaking water from the bilge or live well plugs.
View attachment 712989View attachment 712991
I ordered it from Menards, I really do not care for the company because of prier experiences but we will see.Dwellonroof - I too am in the planning stages of a Pole Barn (30x40 ft). It would have the side lean-to extensions as extra space requirements.
what barn kits have you been looking at ? - that is of interest to me
- my primary use would be for critters (chickens, rabbits, sheep, donkey), feed, supplies, and for equipment storage.
- I certainly plan on having a concrete floor, from the start, ... agreeing with the others
- I'm considering adding a corner 2 pc washroom - toilet, sink, small counter
- given that future storage might include vehicles, I have thought of the space requirements of a car lift also
- I am probably 18 months away from seeing this develop, because I want to pay it outright.
happy planning
I have priced the lumber yard around the corner but they were around 2k higher.If the OP isn't aware, there is a very good YouTube channel that has a ton of videos on building "pole barns". He uses Post & Beam construction, and has convinced me that it far superior to building conventional pole barn procedures.
Sorry to hear that. Guess I'm lucky with the lumber yard I have available. 20%-30% less than the big box stores on virtually everything.I have priced the lumber yard around the corner but they were around 2k higher.
