Backhoe Bh 77 pin will not take grease
/ Bh 77 pin will not take grease #1
m1garand762
Gold Member
ohio
kubota
My bh77 has 1 pin that will not take grease. It removed the zerk and it is clean I sprayed the pin out with carb cleaner it appears to be drilled through. I ran a wire in and the grease that’s in it is not hard but I do not get any grease to the pivot point. I am trying not to have to pull the pin out. Does anyone have any suggestions.
/ Bh 77 pin will not take grease #2
Every now and again, that will happen to my BH76. I've found if I change the pressure exerted on the pin, I can get it to take grease. So, if your BH is resting on the ground, lift it. If it is suspended in the air, then set it on the ground with light pressure. Remember those back hoe's like molybdenum grease
I have gone as far as trying to pump grease with it slowly moving and can’t find the sweet spot. It’s almost as if there was a bur from manufacturing and the grease grime the factory and first few times from me moved it to the end and blocked the exit the machine is less than a year old
/ Bh 77 pin will not take grease #4
Might try swapping the grease fittings from another pin to determine if the zerk or pin is the problem first. Agree that sometimes I have move the joint to allow grease to flow.
/ Bh 77 pin will not take grease #6
Install a new zerk.
If that does not work, remove the pin and inspect.
I once bought a grapple bucket that had one zerk that would not take. Turns out that the hole into which the zerk was installed had not been drilled completely through.
I found two colors of grease on the zerk indicating that at least two folks, probably at manufacturer and dealer, had attempted to grease it but did not care when it would not take.
SDT
/ Bh 77 pin will not take grease #7
Sometimes when looking at a problem it's helpful to make a list of everything it could be, and then solving them from easiest to most difficult.
1. It could be the zerk. Take it out and test it.
2. It could be an incompleted drilling. With the zerk out, you may be able to tell if that is the problem.
3. Only if it isn't #1 or #2, is it necessary to pull the pin.
I guess it is possible that a pin could fit so tightly in the bushing that there is no room for grease...though I've never seen it.
More likely is that incompatible greases were used and they hardened...closing down the necessary clearance for grease to flow. I have seen that, as have most mechanics. It's a chemical reaction that makes a grease into a solid. If that is the case, heat won't help.
rScotty
/ Bh 77 pin will not take grease #8
Had a entry gate hinge that sounded terrible when brother bought the place… it would not take grease.
Brought out my two setting for pressure gun and it was touch and go but it worked…
/ Bh 77 pin will not take grease #9
x2 on the incompatible greases. I tell folks that service their own equipment not the interchange greases, along with brands of greases.
Grease isn't just grease... it's actually highly sophisticated now a days.
/ Bh 77 pin will not take grease #10
Is it building pressure before failing to go in? A damaged fitting won’t seal.
2022 John Deere 5090E (A60462)
2022 John Deere...
2020 Caterpillar 289D3 (A60462)
2020 Caterpillar...
Deere 335P (A53317)
Deere 335P (A53317)
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2015 FREIGHTLINER  2500 4X2 SPRINTER VAN (A59906)
2015 FREIGHTLINER...
2005 KENWORTH T800 OPEN ROLL OFF (A60736)
2005 KENWORTH T800...
