TS354C Parts Manual
/ TS354C Parts Manual #21
Not necessarily. On the TaiShan I owned, power steering had a separate pump with it's own filter. It was hanging off the side of the engine, a silver canister with a replaceable internal filter.
//greg//
/ TS354C Parts Manual #22
Got it.. this is how i see that but im not sure.
1. Oil filter
2. New Hydraulic filter setup
3. Fuel Filter
4. (old hydraulic filter setup?)
Also, I'm planning on draining and cleaning the strainer today.. i found this schematic of the plumbing here. but it's for steering (2004) mine is 1998, but it looks close, and it shows it plumbed into the strainer.. i added the red to show the remaining plumbing in the back for the lift.
I've got the line going into the strainer at #4 and another on the opposite end of the strainer canister. Those red lines for me represent the lift hydraulics and where my attention is.
Also I couldnt find anything regarding this '?' in the picture- that 90コ elbow piece..
/ TS354C Parts Manual #23
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=337679"/>
1. Oil filter
3. Fuel Filter
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=337680"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=337681"/>
#2 looks to be a fuel filter, not hydro.
Chris
/ TS354C Parts Manual #24
That 90 degree elbow piece is a single hydraulic remote, typically for a hydraulic dump bed trailer. If it had a QD connector on it, you'd have probably recognized it yourself. That hex bolt I described diverts hydraulic flow from the rear lift to that elbow. It may also have something to do with why your lift arms don't respond. With the flow diverted and the lift lever pulled up, hydraulic pressure raises a connected trailer bed. When you push the lever back down, gravity pushes fluid back to the sump via the same elbow.
And yes, #2 is a fuel filter. #4 is the original fuel filter housing. A spin-on canister similar to the oil filter screws into the bottom. Apparently a previous owner decided to cap it off, and use an automotive inline filter instead. I'd be inclined to return that to original equipment, as the canister has far more filtration area.
#3 isn't a filter at all, however it does have a screen in the head. That's the fuel sediment bowl. Dirt and water collect there, and must be drained/cleaned periodically.
//greg//
/ TS354C Parts Manual #25
If you still have the PDF I would like to have a copy. My tractor is a KAMA 354X but the manuals are for a TS354C. I don't really know but it sounds like my KAMA is a 3 cylinder version of the TS354C.
I have converted my 354C parts manual to PDF; if anyone needs one just let me know.
/ TS354C Parts Manual #27
I could use your PDF version of the parts manual if you still have it available!
/ TS354C Parts Manual #29
/ TS354C Parts Manual #31
Hi, I would like a copy please. Thank you
/ TS354C Parts Manual #32
Tommy: Do you have a owners manual for a Kama Tractor Model TS354C 4 cylinder. Thanks Dan7992
/ TS354C Parts Manual #33
/ TS354C Parts Manual #34
Noting conversation about KAMA tractors, I have a KM 454.
No service manual nor parts vendor.
Does anyone have a suggestion on whom I may contact for parts/manual?
/ TS354C Parts Manual #35
Sorry I only had one and the other guy bought it, Artrac Tractor in Ark. had some parts and books, may want to see if he can help
If not I May be able to get you one from my Supplier and have him ship with a parts order, the only manuals they have are Tractor parts, Engine, ( need to know what engine your tractor has ) There are NO SERVICE MANUALS for these tractors
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
/ TS354C Parts Manual #37
Re: Woodsman 1234 TS354C Parts Manual
I too would like a copy of the pdf for the TS354S manual.
/ TS354C Parts Manual #38
yes, i would like a copy. working on one and have no manuals.
/ TS354C Parts Manual #39
Tommy said he only had ONE manual book, and that it had been sold. You will have to contact him directly for an update. Afaik, there are NO PDF manuals for this tractor. If you have the Y385 engine, it's the same as in the Jinma 354. Please read all previous posts.
"Artrac Tractor in Ark. had some parts and books, may want to see if he can help."
Maybe you could Google "Kama tractor manuals" and see what pops up.
/ TS354C Parts Manual #40
this kama 354 has a 485t motor, at this moment I have no manuals for that engine. so far google has been no help, but thx any way. we will take any advice on the setting the timing to the injector pump. normal T>D>C> to pump is showing timing off by 94 deg.but engine will run on ether. so cam to crank timing is correct.
500BBL WHEELED...
2011 Jacobsen T-700 Commercial Reel Mower (A61567)
2011 Jacobsen...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
M998 (A55852)
M998 (A55852)
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
