Storing backhoe, stabilizer arms bleeding
/ Storing backhoe, stabilizer arms bleeding #1
thunder86
Southern Indiana
Bobcat ct4045
I cut a 20” log as a backhoe stand to rest on. When I pulled away I thought I could bleed the stabilizer arms down just like I do my front loader bucket but it wouldn’t go. Is it ok to leave it like this and just let it bleed down on it’s own? Or do I need to completely raise those stabilizer arms and pin them? I’d like to keep them down so it helps it not fall over.
/ Storing backhoe, stabilizer arms bleeding #2
If you leave them down your ram cylinders are exposed and will accelerate damage to them.
As this is a new backhoe I would be surprised if they bleed down, seals are likely too new for that.
/ Storing backhoe, stabilizer arms bleeding #3
I’d take it off the log and just put the pin mounts on some shorter blocks. There’s no benefit to being on the log and making of more tip prone. I’d also roll the bucket out and buy the stick all the way out and put the stabilizers up. You want to keep any cylinders possible fully retracted to prevent rust.
/ Storing backhoe, stabilizer arms bleeding #4
It isn't just the cylinder seals that can bleed down, there is also some valve leakage. All cylinders bleed down eventually over long periods of time, especially if they are connected to other hydraulic components. If you are relying on the stabilizers to keep the hoe upright, it may slowly tip as this slow leakage occurs.
/ Storing backhoe, stabilizer arms bleeding #5
There is an old post on here somewhere, where a person parked a backhoe and was counting on the stabilizers to keep it upright. He had a health problem including an extensive stay in the hospital so it was (I think) 2 years before he got back to the backhoe which had fallen over on it's side. I.E. don't count on the stabilizers to hold the backhoe for long periods of time.
/ Storing backhoe, stabilizer arms bleeding #6
How did you try to bleed it down? Were hoses still connected to tractor (but hoe unhitched)? Unhooked hoses are going to be hard to bleed down.
With the male end of a hydraulic hose, you can push in the ball to relieve pressure (and some oil) to lower cylinders, depending on how much pressure is in the hose. Looks like your connection is a female port. I’m not sure if you can work the collar on the female connection to open a passage to relieve pressure, while you’re also working the control lever to lower the stabilizer arms.
So I need to keep as much of the cylinders inside as possible both stabilizer arms and bucket. I believe the log would hold it without tipping over. It’s 20” diameter, if anything I’ll cut another just like it and put them side by side.
With the male end of a hydraulic hose, you can push in the ball to relieve pressure (and some oil) to lower cylinders. Looks like your connection is a female port. I’m not sure if you can work the collar on the female connection to open a passage to relieve pressure, while you’re also working the control lever to lower the stabilizer arms.
I had already unhooked all the lines. I didn’t expect not to be able to drop them. After reading the comments though I’m gonna keep them pinned up and try being the bucket up so that cylinder isn’t out as much too.
/ Storing backhoe, stabilizer arms bleeding #9
Can you back up to it, reconnect hoses (only) and move cylinders to desired position?
Yes. I can reconnect hoses and move them up. Everything is perfect working order, just wanted opinions on what I was doing.
/ Storing backhoe, stabilizer arms bleeding #11
Gravity will cause your retracted stabilizers to bleed down and slowly expose the cylinder rods. Chain the stabilizers together to keep this from happening.
/ Storing backhoe, stabilizer arms bleeding #12
For the Kubota B26 I built a 8” timber pallet to rest on. Manual calls for some blocking. Hoses are too short without some blocking. Greatly helps when hooking up.
The M59 backhoe is happy on the ground. Both are stored in the barn. The hoses are connected and all pressure is relived for storage.
/ Storing backhoe, stabilizer arms bleeding #13
Why rest it that high off the ground? How long will it be off the machine?
I’m a relative newb but on my Kubota L47 (similar to the B26 and M59 listed above) the hoe is considered “power beyond” and do not bleed off like the FEL. Once the lines are disconnected the system is closed.
When I drop mine, after the pins are out I lower it to the ground then disconnect the lines. I have sat it on 2x scraps but have also left it on grass. Rarely off for more than a week though
My hoses aren’t that long. I’m afraid they won’t reach.
currently though I’m trying to reconnect my hoses and I cannot get my hoses to connect for the life of me.
/ Storing backhoe, stabilizer arms bleeding #15
Just occurred to me there could be a temp difference, the guys in the other thread are right. Same thing happens on grapples, you drop them, they sit in the sun all day, then you can’t reconnect. I’ve had to loosen a fitting twice in 5 yrs to reconnect.
It’s helped to connect the fittings when taking it off, helps even out the pressure
/ Storing backhoe, stabilizer arms bleeding #16
I put a tie down strap from 1 stabilizer arm to the other to keep them from bleeding down. I also have mine on an oversized pallet so I can move it around with my forks.
/ Storing backhoe, stabilizer arms bleeding #17
When you tried to bleed down the cylinders, you built up pressure against the couplers. No chance to reconnect them without loosening a fitting and relief pressure.
/ Storing backhoe, stabilizer arms bleeding #19
Unsure if that is fully the case, might be able to use a jack or two to take the pressure off the legs which will reduce the back pressure on the fittings... this is after they cool off in the evening/early morning.
Unfortunately this is a normal consideration of having hydraulic equipment and is almost always an afterthought. We have all done it or will do it at some point.
Got it fixed. Was a cooler morning this morning and they hooked right in. Guess I’ll be using a wrench next to relieve the pressure. Thanks
