Help finding heavy-duty U-channel for custom loader attachment
   / Help finding heavy-duty U-channel for custom loader attachment #1
DVVT
Kioti CK3510 manual trans
I'm trying to modify an attachment to fit in place of my bucket. The idea is to mount some U-channel, like shown in the photos, to the new attachment, so it will accept the loader arm and cylinder ends. The U-channel is approx. 3"x3"x1/4" thick. All I can find online is U-channel with shorter sidewalls ... i.e. 3" wide but say 1-1/2" sidewalls. Am I calling it the wrong thing, or looking in the wrong places? Or is the only option to but square stock and cut one side off?
   / Help finding heavy-duty U-channel for custom loader attachment #2
I would be tempted to find some 3x3x1/4 angle and use two pieces with the legs going away from the pins. You could even add braces from one leg to another to prevent them from spreading under load. Much easier to find angle in that size than channel.
   / Help finding heavy-duty U-channel for custom loader attachment #3
Find rectangular tubing the wall thickness you want, then cut off one side.
Bruce
   / Help finding heavy-duty U-channel for custom loader attachment #4
Just build it. 3 pieces of flat and you’re done.
   / Help finding heavy-duty U-channel for custom loader attachment #5
Is this for the Kioti? Considered converting to Quick Attach?
   / Help finding heavy-duty U-channel for custom loader attachment #6
Converting to Quick Attach is the best option.
you can buy it to fit your tractor:
   / Help finding heavy-duty U-channel for custom loader attachment #7
That is undoubtedly a press-formed part, not regular stock, though the suggestion to use rect tube and cut off one face is a creative one. Assuming you cannot bend steel like that, your best bets are to use angle or the rect tube as previously stated or find a shop that can make/bend it for you. This is not a stock shape you are going to find anywhere.
   / Help finding heavy-duty U-channel for custom loader attachment #8
Or a piece of angle and a piece of flat stock
   / Help finding heavy-duty U-channel for custom loader attachment #9
Maybe 2 pieces of 1-1/2 x 3 x 1/4 angle butted next to each other?
   / Help finding heavy-duty U-channel for custom loader attachment #10
We need an update please.
And pictures of the attachment.
   / Help finding heavy-duty U-channel for custom loader attachment #11
2 pieces of angle turned out would work well
   / Help finding heavy-duty U-channel for custom loader attachment #13
that's the best answer I've heard.
That is the way I built the brush fork frame many years ago:
With a little extra rollback built in:
And chain slots:
It can haul a lot of brush:
2018 Keystone Outback Super-Lite 330RL T/A Travel Trailer (A59231)
2018 Keystone...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61306)
2021 Gehl RT215...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
