My Place: a CAT, Mahindra, and Ducks
   / My Place: a CAT, Mahindra, and Ducks
But these meet the renewable specs.
You can take that and the Boy Scout that let you in the door and go soapbox race yourself.:D I want American steel.
hugs, Brandi
The front bumper spray tank on the lawnmower works way better than expected. I can spray and move along the fence lines, justing my left elbow to steer with the wand in that hand. Or drive slowing and steer with one hand.
At first, I only put in 12 gallons of water & Eraser A/P. Every once in a while the rear tires would spin. I was extra careful along the gully. Last trip of the day, I put in 16 gallons and all worked fine. Now, after all that fab. and install with 3 hours of spraying.............the tank will sit until next year.
hugs, Brandi
Got the CAT grader blade reinforced. 3x3x3/8th inch angle 8 foot long. I drilled #40 pilot holes and took it to my welding shop, were they punched the holes out for 5/8th inch plow bolts.
hugs, Brandi
Made a transport cradle for the grader blade today. Now I can leave it outside. After a year or two, change out the bottom pallet.
With it positioned this way, I just curl the bucket level to the ground and crab in. If needed, I can slide
the blade a little, by hand, to get it in place, then chain it.
hugs, Brandi
Hello, anyone out there?
hugs, Brandi
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A55787)
2006 Magnum 125...
2009 NISSAN Murano AWD SUV (A55758)
2009 NISSAN Murano...
BUSH HOG 1815R1 BATWING MOWER (A51406)
BUSH HOG 1815R1...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
PALLET OF (2) GRACO AIR COMPRESSOR (A54756)
PALLET OF (2)...
