My Place: a CAT, Mahindra, and Ducks
   / My Place: a CAT, Mahindra, and Ducks
But these meet the renewable specs.
You can take that and the Boy Scout that let you in the door and go soapbox race yourself.:D I want American steel.
hugs, Brandi
The front bumper spray tank on the lawnmower works way better than expected. I can spray and move along the fence lines, justing my left elbow to steer with the wand in that hand. Or drive slowing and steer with one hand.
At first, I only put in 12 gallons of water & Eraser A/P. Every once in a while the rear tires would spin. I was extra careful along the gully. Last trip of the day, I put in 16 gallons and all worked fine. Now, after all that fab. and install with 3 hours of spraying.............the tank will sit until next year.
hugs, Brandi
Got the CAT grader blade reinforced. 3x3x3/8th inch angle 8 foot long. I drilled #40 pilot holes and took it to my welding shop, were they punched the holes out for 5/8th inch plow bolts.
hugs, Brandi
Made a transport cradle for the grader blade today. Now I can leave it outside. After a year or two, change out the bottom pallet.
With it positioned this way, I just curl the bucket level to the ground and crab in. If needed, I can slide
the blade a little, by hand, to get it in place, then chain it.
hugs, Brandi
Hello, anyone out there?
hugs, Brandi
2015 Ford Transit 250 Passenger Van (A55788)
2015 Ford Transit...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
CAT 420D IT (A47477)
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
