My Place: a CAT, Mahindra, and Ducks
   / My Place: a CAT, Mahindra, and Ducks
But these meet the renewable specs.
You can take that and the Boy Scout that let you in the door and go soapbox race yourself.:D I want American steel.
hugs, Brandi
The front bumper spray tank on the lawnmower works way better than expected. I can spray and move along the fence lines, justing my left elbow to steer with the wand in that hand. Or drive slowing and steer with one hand.
At first, I only put in 12 gallons of water & Eraser A/P. Every once in a while the rear tires would spin. I was extra careful along the gully. Last trip of the day, I put in 16 gallons and all worked fine. Now, after all that fab. and install with 3 hours of spraying.............the tank will sit until next year.
hugs, Brandi
Got the CAT grader blade reinforced. 3x3x3/8th inch angle 8 foot long. I drilled #40 pilot holes and took it to my welding shop, were they punched the holes out for 5/8th inch plow bolts.
hugs, Brandi
Made a transport cradle for the grader blade today. Now I can leave it outside. After a year or two, change out the bottom pallet.
With it positioned this way, I just curl the bucket level to the ground and crab in. If needed, I can slide
the blade a little, by hand, to get it in place, then chain it.
hugs, Brandi
Hello, anyone out there?
hugs, Brandi
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2021 JLG T350 PORTABLE ELECTRIC SCISSOR LIFT (A52705)
2021 JLG T350...
40" WIDE STAIRCASE W/ METAL RAILING (A54757)
40" WIDE STAIRCASE...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
RIGID TOOLBOX (A52472)
NEW HOLLAND TN95EA TRACTOR (A54756)
NEW HOLLAND TN95EA...
