My Place: a CAT, Mahindra, and Ducks
   / My Place: a CAT, Mahindra, and Ducks
But these meet the renewable specs.
You can take that and the Boy Scout that let you in the door and go soapbox race yourself.:D I want American steel.
hugs, Brandi
The front bumper spray tank on the lawnmower works way better than expected. I can spray and move along the fence lines, justing my left elbow to steer with the wand in that hand. Or drive slowing and steer with one hand.
At first, I only put in 12 gallons of water & Eraser A/P. Every once in a while the rear tires would spin. I was extra careful along the gully. Last trip of the day, I put in 16 gallons and all worked fine. Now, after all that fab. and install with 3 hours of spraying.............the tank will sit until next year.
hugs, Brandi
Got the CAT grader blade reinforced. 3x3x3/8th inch angle 8 foot long. I drilled #40 pilot holes and took it to my welding shop, were they punched the holes out for 5/8th inch plow bolts.
hugs, Brandi
Made a transport cradle for the grader blade today. Now I can leave it outside. After a year or two, change out the bottom pallet.
With it positioned this way, I just curl the bucket level to the ground and crab in. If needed, I can slide
the blade a little, by hand, to get it in place, then chain it.
hugs, Brandi
Hello, anyone out there?
hugs, Brandi
2005 TerraGator 8104 (A55301)
2005 TerraGator...
2008 Ford Focus SEL Sedan (A54815)
2008 Ford Focus...
UNUSED FUTURE ST60 HYD SIDE SHIFT FORKS (A54757)
UNUSED FUTURE ST60...
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2018 JCB Truss Jib Telescopic Hydraulic Boom (A55787)
2018 JCB Truss Jib...
2015 Dodge Grand Caravan (A47477)
2015 Dodge Grand...
