25hp Tractors for Vegetable Farming
/ 25hp Tractors for Vegetable Farming #1
Iowa Hillbilly
The Hills of Eastern Iowa
Case 2590, CIH 685, Case 400
I'm looking to get into vegetable farming and am considering getting a couple of 25hp tractors to do it. There are a lot more options on the market than I expected and I'm not sure which model(s) would work best for me. I plan on having beds that are 36" wide with 18" pathways in between and I want to be able to straddle the beds, so tread width is very important for me. The biggest task for them will be wagon pulling, but I also plan to use them for a 36" tiller, potato digger, flail mower for maintaining fence lines, running a PTO generator, and maybe a wood splitter. I don't need or want a cab for this. I may get a loader for one of them for odd jobs, where a small machine comes in handy. I generally prefer larger displacement, lower rpm engines for longevity and heavier weight machines. I plan for both to be hydrostat transmissions and I want them to be easy to operate for inexperienced tractor drivers.
I've got three models on my short list right now: the Mahindra 1626 HST, the Kioti CK2610 HST, and the Branson 2515H. Kioti lists the front and rear tread width for their tractor on the spec sheet, but Mahindra and Branson don't. I can more or less figure it for the rear axle by subtracting a tire width from the overall width, but the front tread width is a mystery. Does anyone know the front tread widths for those machines? Do any of these models have electronic engine management or are they still mechanical injection? I like to keep it simple.
I'm not at all concerned about putting spacers on the rear axles to widen them out, but I'm somewhat hesitant to try that on the front for fear of messing up the steering radius/geometry and exposing the king pin to potential rock hits. Does anyone have experience with front axle spacers who can educate me on this? I'd appreciate any help you can give me or experience you can share with me about this.
/ 25hp Tractors for Vegetable Farming #2
One thing to keep in mind, is the tire choice. With R1 tires, most manufacturers offer a width adjustable rim. Usually just for the rear wheels. Here in Europe, on the Branson, if the owner chooses R1 Radial tires, he will get both front and rear width adjustable rims.
I think the Branson meets your criteria really good. It's an heavy tractor, very heavy duty construction, pretty much all mechanical, low revving engine (PTO 540@2200 engine rpm) since it's a detuned engine from the higher HP models and has a large displacement for the sizer at 1.7L. It does have an independent PTO and very good lifting specs both at the loader and at the 3 pt.
I can share the tire tread width for the higher HP models of the Branson. This is from the manuals for the 3015, 3515 and 4015.
/ 25hp Tractors for Vegetable Farming #3
Not sure if you have an LS or New Holland dealer nearby, but they also have a tractor similar to the Kioti you're looking at. The LS may be substantially less in cost..... worth it to at least look....
If they have width adjustable rims that would be very helpful. Looking at the online pictures I thought they looked like they were fixed. I think that's typical for tractors in this size range in the US, but maybe they offer an adjustable wheel as an option?
/ 25hp Tractors for Vegetable Farming #5
Only with R1 tires I believe. Once you choose R4 or Turf, you get a fixed center rim. But definitely confirm this with the dealer of whatever brand you end up buying.
I'm checking out LS models now. This is actually the first time I've ever heard of them. I looked at the New Holland models previously, but I didn't find quite what I was looking for.
/ 25hp Tractors for Vegetable Farming #7
My 15 series Branson has R1 and adjustable rims.
I just realized Branson is not offering a 25hp in the 20 series anymore.
/ 25hp Tractors for Vegetable Farming #8
Some 2-WD tractors have adjustable wheel widths in front.
That's cool. Does the manual say how wide or narrow you can adjust them too?
/ 25hp Tractors for Vegetable Farming #10
Here is a picture from the Branson 15 series manual. The front is adjustable to two different positions The rear 4.
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2017 CATERPILLAR 420F2 BACKHOE (A59823)
2017 CATERPILLAR...
159119 (A60430)
159119 (A60430)
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
KBH Tender Trailer (A61307)
KBH Tender Trailer...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
