Show your trailer sides
/ Show your trailer sides #41
Search saves the day again! 6 pieces held together with door hinges and hairpin cotter pins at the corners and side section junctions Pure Genius! THANK YOU!!!!
I don't have pics of my sideboards but I did something similar to UpNorth1. I have a 16-foot trailer so I used 1x8 southern pine boards and made the sides in 2 pieces (8-foot each) so they are easier to handle. Then I mounted them to 2x4's that run down into stake pockets. The only difference is instead of hinge pins I just used the trailer connectors that are made for this:
Sides:
Amazon.com: Buyers Products B2585BZ Straight Stake Rack Connector Set: Automotive
Corners:
Amazon.com: Corner Stake Rack Brackets, Normally Used for Connecting Trailer Side Panels, 2 Corners Both Left and Right Hand Sets: Home & Kitchen
I actually went a little farther and mounted 3/4" galvanized conduit the length of the sideboards on the outside about 12" below the top. I then bowed some 3/4" PVC pipes crosswise inside the supports. Now I can stretch a tarp over the top and use bungees to strap it down to the conduit.
It will be a little while until I have this set up again (I usually don't keep the sides on my trailer). Once I get it installed I'll try to take some pictures and update this post.
/ Show your trailer sides #42
I always loved wooden sides. Is there a possibility to order a modern pick up truck with a bed made of wood in the US?
/ Show your trailer sides #43
I showed the sides for my 16' trailer early in this thread. Here are the sides for my 10' trailer, wood slats for the front sides & ends, ramps for the rest of the sides: HPIM3264.JPG
The 4 x 8' Snowco just uses aluminum ramps: HPIM3162.JPG
/ Show your trailer sides #44
BOY,,, I am lazy compared to you "side creators",,,
I dropped in a board,, and put a single screw in each board,,,
I have hauled stone level full to the top of those boards,,, :eek:
/ Show your trailer sides #45
Here are two external style sideboard latches:
/ Show your trailer sides #46
Same ones I used. I also had the straight version of the corner brackets to join 2 pannels together. Dont remember if I used the straigh or angled sliding bolt latches. Same thing only has the non moving bent 90 or not so you can install them on a corner or straight, depending on where your mounting post is.
/ Show your trailer sides #48
Not quite a trailer, but in the same spirit:
/ Show your trailer sides #49
I’ve split more regular limber than I care to count for dump truck sideboards. Oak isn’t a lot better but the pine is worthless. I’ve found double layered advantec to hold up pretty good. I’d like to have some laminated beam but it’s $10 a foot.
/ Show your trailer sides #50
Put wood sides on my 18’ dovetail equipment trailer. Used pressure treated 2x4’s and 5/4 x 6” deck boards. They’re HEAVY! I can get the tailgate off by myself, but the 16’ sides are difficult even with 2 strong men. Luckily, I have this tractor. Throw two lifting slings around it and they come off easy. It’s nice to have both a flatbed for hauling the tractor or picking up pallets with stuff and a utility trailer as well. The sideboards are 32” high from the deck of the trailer.
/ Show your trailer sides #51
Pressure treated looks good when it's new. You gotta keep after it or it will bow, crack and split with the best of them if left outside. After it dries a little, I'd be coating it.
One of these days I'm going to have to replace some treated fence posts I had in corners. I used a double H pattern and every one of the cross posts disintegrated and fell out. :confused:
/ Show your trailer sides #52
/ Show your trailer sides #53
I can get 2.5 cords of heavy oak with room to spare.
/ Show your trailer sides #54
/ Show your trailer sides #55
You could probably do more than that but I guess 2.5 cord is about your payload. I used to get that much on my 10’ bed dump truck.
Yep. Weight's a factor. And usually load with skid steer bucket in bulk, no stacking.
/ Show your trailer sides #56
What does that trailer weigh empty? My bumper pull 14’ 16k weighs 4600 pounds. Are those 8 or 10k axels?
Titan 20.5-25 Tires (A65640)
Titan 20.5-25...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
IH 1486 Tractor (A66285)
IH 1486 Tractor...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
