What machine do you have it on? Is visibility a problem with other implements also - bucket, etc?
It is on a LS4140 Cab. And yes, I have issues with seeing any implement that is engaged low to the ground. Even hooking up the SSQA is a PITA and that is why I need the camera.
If you can weld you might be able to add the 3 point mounts, here is one for John Deere that fits front or rear: Buckthorn Puller@ranger danger how is yours attached to the 3 point? i world like to replicate your setup
Bmaverick… I’ve seen this before but it’s still pretty neat.
How much$$$&??I have posted before and stick by it, the INTIMIDATOR is great! From small to big it will work, there is a little issue with the site over the hood (JD 5225) but it works as advertised. I have used it to dig roots on things that wouldn't just pull out. I have also used it with brush on a fence line, cut limbs off of the fence and then just pull out, no hassle. The group pictured below took less than 10 minutes to pull out and no damage to the fence. I like the idea of the 3 point hook up, Thanks for that!
View attachment 708016View attachment 708021View attachment 708022View attachment 708023
Thanks, this looks like something I definitely need on my list.I've had mine for 4 years. Pulls tree's up to 6" easy and 8" with a little extra work. I pull ceanothus bushes about 3" around and 30 feet tall with ease. I use the " jaws of death" on the 3 point and a grapple on the the fel. Makes for quick easy work!
. View attachment 707929
How much$$$&??
We have one for our JCB skid steer. It works great. I pulled over 200 buckthorn out in less than 2 hours. Buckthorn root system doesn't go very deep, so they are easy to pull. It will pull out some good sized trees as long as the weight isn't too much for the counterbalance on the JCB and you can break the roots lose. When the trees get too big, we use the backhoe.Looking for anyone who has used the Titan hydraulic clamping tree and shrub puller, or, another “economy” similar tool. ($900-$1200).
How did it perform?)
Do you have to get studies and permits before you can pull trees in California? I thought I read somewhere that y'all have to get an environmental impact study and someone from DNR to approve any removal and a shaman to bless the trees before you can get started. OK, the shaman thing may have been a bit of a stretch.
Got ours for $2800 in May of 2020, I spoke with Glenn Danuser, he called me within 5 minutes of an email I sent because I wasn't sure how to put it on a JD hook up. I decided to buy a Worksaver adaptor for JD to Skid Steer connector which was $700. I was looking at the Titan JD to Skid Steer but the Woksaver is made in the US and the welds looked better to me, plus reviews of Titan weren't very good. Reviews for the Titan adaptor indicated many people had to modify the pins. The Worksaver fit perfectly and has taken the abuse.1.5” square tubing costs 70% more than 7 months ago so no idea what they cost now. Had trouble getting the local CO-OP ordering one and Dan Danuser got involved which I feel I got good faith discount years ago. They don’t sell directly and have to go thru “dealer”. $2.050.
