Anybody use Titan shrub puller
/ Anybody use Titan shrub puller #1
TmbrWlkr
Kubota l3400
Looking for anyone who has used the Titan hydraulic clamping tree and shrub puller, or, another “economy” similar tool. ($900-$1200).
How did it perform?)
/ Anybody use Titan shrub puller #2
We have a generic one... pic below... Great attachment for small stuff, just have to remember the limitation of the FEL... We use it all the time... (& we purchased still new... for a crazy low price at an auction, which made even a better deal...)
Pic of it on our TC40D...
I have an adaptor plate for the 3 Point hitch which will allow us use it on the 3PT also... but haven't used it that way yet... but should have much greater pulling power for stumps...
/ Anybody use Titan shrub puller #3
I recommend increasing the budget and getting a higher quality puller: Buckthorn Puller
And then there is this version:
I have a Hawthorne “problem” - small, scrubby, Very thorny trees; shallow routed though. Thorns will penetrate leather gloves. Looking for a solution to get them to the burn pile without handling them, but not a commercial venture.
Do you know the brand - it looks pretty nice with a push bar. Would you say it will handle 2 1/2” trees?
/ Anybody use Titan shrub puller #6
Danuser Intimdator has good reach, maneuverability and easy to operate with a tractor FEL. Option of digging out much bigger trees. Nice protector for the thorny stuff. Very useful for us. Costs more, does more.
/ Anybody use Titan shrub puller #7
Maybe I'm being phobic but putting a tree puller on a tractor loader that's off set to one side presents issues for the loader?
/ Anybody use Titan shrub puller #8
I use my grapple with the adaptor plate I added to it. It will hold on to and pull anything that the hydraulics of the loader can handle. You can read about its development below:
/ Anybody use Titan shrub puller #9
@TmbrWlkr - we pull 2 1/2 - 3" stuff (especially if it is shallow root stuff), if it is stubborn stuff we just rock it back & forth & it usually pulls.
The most important thing is awareness of your tractor's FEL / hydraulics capabilities & not push it... You can definitely break stuff...
I believe ours is made by Mid-State Attachments (I can check)... again we bought it at an auction (actually 2 of them) & a 48" grapple... all new... super cheap. They are not the heaviest built nor the quality of some of the above mentioned units. I looked at them all & decided for our use & the ability of our machine these would work well for us. They are also lighter in weight then most I looked at, which was important to me as every pound a the attachment weights it takes away from the loader. If I had a big machine or a skid-steer I might have purchased a much more robust unit but our machine will never pull the stuff those implements are designed to pull...
So, for us this was an incredible purchase for the price & has worked very well for our needs...
/ Anybody use Titan shrub puller #10
With pullers sometimes you can grab and pluck with the FEL. Most times grab low and push forward will uproot with more force.
Been my observation that tree pulling is much easier in the early spring with less ground disturbance. Roots just slip out of the ground easier.
A piranha toothbar is great and faster than a grapple taking out the brush and small trees. Making piles. The V-shape teeth grab the stems and pulls up the small trees or brush by the roots. Most impressive clearing tool. Con is it can’t carry brush very well.
The con is not that big as I already have a brush grapple. I’m visualizing making piles then moving them with the grapple.
/ Anybody use Titan shrub puller #12
I have an MTL and it cost about $1000. There are two issues. First is on smaller tress, say less than about 2 1/2" inches it is easy to shear/snap the tree. Second is seeing what you are doing. I am getting a backup camera to address that.
I have plenty of FEL capacity (2700 lbs) so that does not limit me.
I use a Piranha Bar on the FEL for small stuff and it does a decent job. I think a Ratchet Rake would be better but I am too lazy to put it on an off when I need it so went with the PB.
What machine do you have it on? Is visibility a problem with other implements also - bucket, etc?
/ Anybody use Titan shrub puller #14
I have a mtl on my L3901, most successful when ground is very dry with lots of counterweight on the 3pt. I have lots of smaller sweet gum trees and between 2 and 4 inches in diameter seems to be ideal, smaller and the pressure smashes the trunk. Larger and I cannot pull the tree out even rocking back and forth. If the ground is wet then i don't have the traction to rock back and forth even with R1 tires and 4wd.
/ Anybody use Titan shrub puller #15
I've had mine for 4 years. Pulls tree's up to 6" easy and 8" with a little extra work. I pull ceanothus bushes about 3" around and 30 feet tall with ease. I use the " jaws of death" on the 3 point and a grapple on the the fel. Makes for quick easy work!
/ Anybody use Titan shrub puller #16
@ranger danger how is yours attached to the 3 point? i world like to replicate your setup
/ Anybody use Titan shrub puller #17
I have a quick hitch to 3 point adaptor so I can run all my fel implements on the 3 point as well. I got it from Titan. I looked but I could not find a pic. Ill look some more.
/ Anybody use Titan shrub puller #20
. View attachment 707929
I used mine the same way.
Puller on the back, grapple on the front
Cleared out several acres of 2-5” gum tree saplings. Worked great.
New/Unused Landhonor 21ft x 13ft Metal Carport (A65583)
New/Unused...
2007 PETERBILT 379 6X4 TRI/AXLE DAY CAB TRUCK TRACTOR (A59914)
2007 PETERBILT 379...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
NEW 2025 Trailer by Premiere Single Axle 12' Tilt  (A62679)
NEW 2025 Trailer...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
