How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #71
Ok lets try that again. Not only what Bobcat or Deere thinks. Rather, in general:
When thread locker is applied to clean dry threads, and looking at a chart of recommended torque for specific bolt sizes - which row in the chart below applies?
librication-jpg.707382
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #72
Maybe a little reading....
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #73
Thank you! That is a must-read.
For anyone who just wants to see a half-vast summary of the article:
Chris Manger of Loctite Western Australia ... results of the Loctite testing clearly confirmed that different brands and types of thread-lockers provide very very different amounts of preload/stretch when the bolt is tightened
Some (Many) thread-lockers simply act as an unreliable and non-predictable lubricant and most provide unpredictable, non-constant preloads. ... can and will result in excessive preload resulting in broken bolts if you actually tighten them to the required torque
...we were advised that the Loctite range of Thread-Lockers are designed to simulate as close as possible to a dry bolt torque condition.
and:
  • Zinc plated bolts require 40% more torque than Black (Unplated) bolts
  • Cad Plated bolts require 25% less torque than a Black (Unplated) bolt.
It's well worth it to read the entire article. Again, thanks.
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #74
/ How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #75
Lost in the translation: 600 Nm is 442 Ft-lbs. That makes more sense to me.
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
2012 Chevy Impala Sedan (A61569)
2012 Chevy Impala...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2019 BOBCAT E45 EXCAVATOR (A59823)
2019 BOBCAT E45...
2014 BMW 5 SERIES 4 DOOR CAR (A59906)
2014 BMW 5 SERIES...
