How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder.
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #71
Ok lets try that again. Not only what Bobcat or Deere thinks. Rather, in general:
When thread locker is applied to clean dry threads, and looking at a chart of recommended torque for specific bolt sizes - which row in the chart below applies?
librication-jpg.707382
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #72
Maybe a little reading....
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #73
Thank you! That is a must-read.
For anyone who just wants to see a half-vast summary of the article:
Chris Manger of Loctite Western Australia ... results of the Loctite testing clearly confirmed that different brands and types of thread-lockers provide very very different amounts of preload/stretch when the bolt is tightened
Some (Many) thread-lockers simply act as an unreliable and non-predictable lubricant and most provide unpredictable, non-constant preloads. ... can and will result in excessive preload resulting in broken bolts if you actually tighten them to the required torque
...we were advised that the Loctite range of Thread-Lockers are designed to simulate as close as possible to a dry bolt torque condition.
and:
  • Zinc plated bolts require 40% more torque than Black (Unplated) bolts
  • Cad Plated bolts require 25% less torque than a Black (Unplated) bolt.
It's well worth it to read the entire article. Again, thanks.
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #74
   / How the heck do you guys torque a cylinder nut to 600 ft lb? Rebuilding Bobcat combo bucket cylinder. #75
Lost in the translation: 600 Nm is 442 Ft-lbs. That makes more sense to me.
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
Electric Mobility Scooter (A51694)
Electric Mobility...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
