F-3990 wheel spacers?
/ F-3990 wheel spacers? #1
Sigogglin
Goshen, VA
New Holland TC45DA
I just got my new to me 2019 F3990. Anyone know if you can get wheel spacers? If so where?
So far it has cut well. I mow about 10 acres per week around the house. Some of it is quite rough, but I've found if I go slower on the rough parts it actually does extremely well. Very happy with it so far. Except for the seemingly random breaking of the windshield glass. I've no idea why it broke, I was driving down my driveway and it just popped and exploded everywhere. I took about 2 hours to get it all cleaned up so I could finish mowing. Cab is not so good with dust when it's missing a windshield.
Yep, it isn't covered by the warranty :)
It has DPF and does go through regens, but the only reason I know they happen is because the idiot light on the console tells me.
Before:
After:
thanks
david
/ F-3990 wheel spacers? #2
Nice looking mower, too bad about the windshield.
Is that aftermarket cab, or was it made by Kubota?
So I measured the wheels and they are 5x4.5. Turns out this is a common size for cars as well. Any reason I couldn't use a car wheel spacer for the mower? Something like this?
/ F-3990 wheel spacers? #5
When your windshield broke, was the mowing deck up or down?
Im thinking your deck got to bouncing and struck the bottom of your cab floor and the shock of the strike broke your glass?
It was up, I was wondering the same thing. That little handle you pull to tilt the deck can get pretty close to the windshield.
/ F-3990 wheel spacers? #7
I see the way mine wildly flops up and down if I go too fast it’s it up, so I tend to run slower with it down, unless I’m on smooth lawn or pavement.
I installed my new windshield. Here is a picture of the lever and how close it gets to the windshield when the deck is all the way up. I decided to remove the lever and the gas cylinder as I only need them when I replace the lawn mower blades.
/ F-3990 wheel spacers? #9
take a look at your old weatherstripping and see if you can see any evidence of the lever having hit. It may be worth having a discussion with your dealer about warranty.
/ F-3990 wheel spacers? #11
.................snip.............
Why do you want to install wheel spacers - concerned about tipping over or?
Sorry for the long delay, real life got in the way.
Yes, we have some pretty steep slopes to mow. I did fill the tires and that helps a lot. I have parked the mower on the slope and tried to move the mower side to side and couldn't budge it, so I think I'm OK if we mow slowly. The uphill tire is still quite attached to the ground.
MACDON FD235 - 35' DRAPER HEAD (A64278)
MACDON FD235 - 35'...
2012 Chevrolet Silverado 1500 Hybrid Crew Cab Pickup Truck (A64556)
2012 Chevrolet...
2022 GEHL RT215 SKID STEER (A65053)
2022 GEHL RT215...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2003 Freightliner MC 331 2,800 Gallon Fuel Truck (A64194)
2003 Freightliner...
