Suggestions for tractor loader
/ Suggestions for tractor loader #1
jfkid
Ford
Hi! Long time lurker could use your advice:
I will be building a home soon with 1/2 mile driveway. I plan to contract out the home build but will plan to do all the landscaping after construction myself. Also will plan to snowplow out the driveway an average of 2-3 times a year. I am thinking that a compact or full size backhoe loader would be ideal. A Deere 110 or Yanmar CBL40. Is there some similar tractor loaders that were loaders without the backhoe? Can I save some money that way without sacrificing loader performance?
I can borrow a 5 ton mini excavator, 4 ton dozer, farm tractor with 3 point & pto, and a single axel dump truck. I’m in Eastern Washington.
Thanks for any ideas or advice!
/ Suggestions for tractor loader #2
Please provide more details. What works for all of us may not work for you you may need a subcompact or you may need a 60 horse machine without better clarity the repsponse will be all over the place
/ Suggestions for tractor loader #3
Something like a JD110 is a nice sized machine. Kubota also makes some construction grade machines in 3 different sizes. It might be something to keep for a few years and then sell and get a regular tractor.
Do you plan on mowing with it, handle brush and firewood? Till and plant a garden? Build fences? All that will affect your long term solution.
/ Suggestions for tractor loader #4
A true tractor loader is a rare beast. It's a permanently mounted front end loader on a tractor with a 3pt hitch. The loader is not removable easily. I had one. A mid-late 70's International IH2500B. It was an industrial unit, not an agricultural unit. Other than being 2wd (did not like my sandy soils), it was a really good option for a machine. It was built to take the abuse of a front end loader. The front axle was beefier. It was a low tractor. You straddled the transmission hump. So it was not a walk-through operator's station. You had to climb over it. It was also 8000#. The 3pt was the exact as it's agricultural counterpart, the IH574. It had draft control, as well as position and depth control.
I don't know that anyone makes a true tractor loader anymore.
/ Suggestions for tractor loader #5
Mine was almost identical to this photo from tractordata, but yellow.
/ Suggestions for tractor loader #6
My suggestion would be to skip the backhoe and just get yourself a CUT with a loader. Those are basically just toys if you have access to a real excavator. If you can find a pre tier-4, low-hour, 45ish hp model with low hours, I would take that over a new one any day. Set it up with loaded rear R-1 tires, a block heater, and a back blade and you will have a snow clearing beast.
Something like this 1000 hour, 2005 John Deere 4120 would be perfect:
/ Suggestions for tractor loader #7
If you have access to a 5 ton MiniEX not sure you need a backhoe. How many acres are you managing? I have a permanently attached loader only M62, but it is a construction grade machine. Kubota also makes a 26 and 47HP version..but again they are expensive. I got this because I was able to do all of the dirt work for my house build (foundation, trenching, backfill, etc) and most of my property is trees or rocks. No farmland/mowing/plowing.
Lets start with your acreage, then what type of work you expect to do.
So far:
1. snow lowing 2-3 times a year on a 1/2 mile drive. Is it gravel/rock?
2. landscaping for a new home? You can probably rent a weekend machine and finish it all. It also sounds like you have access to what you would need to accomplish this 1 time task.
No mowing, field work? Just trying to get a good idea of the tasks.
/ Suggestions for tractor loader #8
Really, if you're gonna be plowing 1/2 mile of driveway, a plow on a pickup is so much faster, and way more comfortable. Zip out the drive, turn around, then zip back in. Done with the long part in 5 minutes.
/ Suggestions for tractor loader #9
I agree. I have a RTV 1100C, heated cab with a Boss V Plow and studded chains. It does great on my 1/4 mile disintegrated granite drive. It sure beats getting pelted with snow on the M62.
/ Suggestions for tractor loader #10
I plan to contract out the home build but will plan to do all the landscaping after construction myself. Also will plan to snowplow out the 1/2 mile driveway an average of 2-3 times a year.
The Deere 110 and Yanmar CBL 40 are construction machines weighing circa 7,000 pounds, ill suited to landscaping and plowing. Well suited to rutting moist soil when the construction machine rolls over it.
$70,000 new.
You need a compact tractor with a bare weight of 2,500 to (probably) 4,000 pounds. Compact tractors within the 2,500 to 4,000 pound weight range ample for five to fifteen 'tractorable' acres.
$25,000 to $40,000 new
Impossible to narrow down the recommendation without more information from you.
How much total acreage do you have? Flat or hilly?
How much of that acreage will you operate a tractor on? Flat or hilly?
What do you intend for above land?
Do you have previous tractor experience?
What is your location?
/ Suggestions for tractor loader #11
Welcome to TBN and the forum - jfkid. So you are over here on the dry side also. Well - unless conditions change - it could be a long wait before you need to plow any snow. I've got a long driveway and haven't had to plow even once in the last three years.
There could well be better choices for what you plan on doing. Start with a list of projects - this will guide you to the best options.
2022 Bobcat E42 (A64126)
2022 Bobcat E42...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
213091 (A64276)
213091 (A64276)
New/Unused Pallet of Webbing Slings (A65583)
New/Unused Pallet...
Pro Tech HD Grapple (A65563)
Pro Tech HD...
