Compact telehandler
/ Compact telehandler #321
I was told my Lull will pick it's front end off the ground. Will your's?
It always nice to have an extra piece of equipment available.
hugs, Brandi
/ Compact telehandler #322
Yes, it can come off the ground a pretty good piece, which at first i freaked, but now its routine, esp for me when using stump bucket. Xfaxman has some good pics of front end up!
/ Compact telehandler #323
Like this fake wheelie:
/ Compact telehandler #324
I used "dry" lubes for the telescoping boom wear pads on my telehandler. I was always of the opinion that grease or oil would attract and retain dirt/grit accelerating wear.
/ Compact telehandler #325
Finally finished up- headin home- it was a good day in my 417
/ Compact telehandler #326
hugs, Brandi
Since no one commented on the Fake Wheelie, here is the real picture:
I was compressing the cedar trees that I dropped on the brush pile. Right after I jumped out to take the picture I realized I might not be able to climb back in. :oops:
Took the picture, opened the door and was able to push up on the joystick, letting the front down. :D
/ Compact telehandler #327
Glad you let us in on that…ive been wondering how in the heck did he do that-he really knows how to drive that machine
/ Compact telehandler #328
That’s only like 2’ of air.
/ Compact telehandler #330
Driveway Straightening
Moved some dirt and gravel with the bucket on the V417.
Looking north:
Looking south:
14 tons of crushed concrete:
Where the gravel was (only 2 inches deep):
/ Compact telehandler #331
Moving dirt back:
/ Compact telehandler #332
Went to get picture of zerks...
Lol. Someone felt that under the boom was a secure location to raise a family.
You can see the bottom two at the base off the hydraulic calendar. Two more at the top:
/ Compact telehandler #333
Took zerk pictures on the V417. Top of cylinders:
Bottom, the zerks are on the other side:
Can be reached through this opening:
The back arrow points to the zerk for the leveling cylinder, the one for the lift cylinder is behind the hose where the front arrow is pointing:
/ Compact telehandler #334
Recent pictures of the brush hog:
With the boom fully extended:
On the ground cutting:
/ Compact telehandler #335
Used the 6' landscape rake to get rid of old hay on the dirt.
This is from last year with round bales in the back of the barn:
This is what I raked out:
Raked and ready for this years round bales:
8, 5x6 bales, two rows of 3 and two on top of the first row.
They are setting on upside down 4x4 plastic pallets so air can circulate under the bale.
/ Compact telehandler #336
I'd get it just so you don't walk under loads. I actually saw one fail once. Right after a fellow walked under it. I mean right after. He walked under two full pallets of can soft drinks. It fell without hesitation or delay.
/ Compact telehandler #337
Get what?
/ Compact telehandler #340
He probably clicked into the 1st page where someone is deciding whether or not to buy a compact telehandler.
I think you are right. From the first page:
The other issue with most skid steers, is we often work alone. This requires getting out of the cab with the lift in the air. Never liked walking under anything lifted. (If the skid had failed the load would have landed on the planter but there are times when I have no choice.)
With the V417 boom up, using the side door is safer.
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2007 International 8600 Parts Truck (A63118)
2007 International...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
