Just another junk chainsaw
/ Just another junk chainsaw
Could just be the pic. But being they dont make outwears for a 500 air filter. It might not even fit across thatair filter and leaving gaps running it.
Looks like a rubber band stretched to its limits and not even fitting on there.
500 af looks wider? You have a HD2 from a 44 66 88 to compare?
Compared to a 44 66 88 HD2.
/ Just another junk chainsaw #1,042
:oops: Just got to ask. You keeping your chains sharp? Chips not dust or maybe your milling?
Thats sad IMHO. Not seeing that here.
You know the 500 filter is not even on the outwears list for fitting that filter. ? Maybe not even fitting it right? Chainsaw Pre-Filters, Stihl
Looks like you need the max-flo.
My chains are sharp I’m out in the PNW where the dust off the bark is something else. If I’m cutting old growth style Doug Fir you will see a cloud of dust from the bark well cutting it gets on everything and into everything.
It’s not listed but it is made for the 500.
A max-flo would be nice but what would be nicer is if Stihl could get their act together and finally produce a filter setup that doesn’t allow fines past from day one like Husky does.
Fines gets by this HD 440 every time it is dropped off for work. Even with stihls prefilter.
But I know he pushes his chains to dust mode. Because I sharpen his chains when they come in too.
Came in for hard to start and throwing chains.
He had actually threw some parts from it he was so ticked at it.
/ Just another junk chainsaw #1,044
Not quite as aggressive as I’d run normally in Doug Fir but you get the idea.
I used to hand file square and do square on grinder. Gave that all up.
She lives and starts easy again. :giggle:
Give it a year ;) she will be back in again.
Put a new bar on for him with new rim etc to see how these bars wear.
Picked up 2 61cc and a 38cc TH. Folks always asking for parts. But I already got 1 61cc running good.
Original homeowner saws that wasnt used anymore.
Other one thin rings and chrome bore.
I'll post the bare bore thick ring again too.
Both red 3.7
Needed a recoil shell for the last 3.7 saw. So instead of buying just a recoil I bought a whole parts 3.7 red saw.
What luck another 3700 61cc thin ring top.
Never saw a mag one break like that. Explains pulley wobble.
Echo oem line, redneck rebuild of oiler check valve with new duckbill.
2.3AV same as 38cc 2300AV
Pulling piston from the 3rd 61cc thin ring chrome bore I am using for parts to help others and recoil shell for one of mine I am going to sale.
These are pressed on.
:cry: 12 dropped off. Get as many going right as can. :cry:
Sometimes you just got to shake your head in amazement when folks try and do their own work. 🤦‍♂️
Missed the routing by a bunch and across the cylinder.
Good thing they dropped it and broke case before burning through fuel line.
That red saw ended up a parts saw. Coil into a grey 2300cva for owner. Redneck check valve fix for oiler. 2000 new lines, 1800 new lines and carb from red.
Craftsman 3.4 poulan 3400 56cc I took in trade.
I am seeing more and more of this type of stuff lately. :oops: :rolleyes: Hopefully you see the issues. :giggle:
/ Just another junk chainsaw #1,060
On my echo CS-490 with a 20" chain, I keep getting the nose freezing up and stopping the chain.
Seems to be using plenty of oil and nose gear is greased.
Have this on two bars. using good/same bar oil I always use.
Bucking dead ash. It's a pain when halfway through a 15" or so branch and chain stops.
Any ideas what I should look for. One bar is new, only a few hours and never pinched.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
UNUSED JCT HYD TREE PULLER (A65055)
UNUSED JCT HYD...
LONG 10 WHEEL V-RAKE (A64278)
LONG 10 WHEEL...
UNUSED JCT-72" HYD TILLER (A65055)
UNUSED JCT-72" HYD...
HONDA FOUR WHEELER (A65054)
HONDA FOUR WHEELER...
2160 (A65055)
2160 (A65055)
