Which o ring material is best for hydraulics?
/ Which o ring material is best for hydraulics? #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
I need to replace an o ring on my hydraulic system and have both rubber and viton (fluorocarbon) on hand. Which is better for this application? I'm leaning towards the viton this time. They're $$$$ but, I've already got them.
/ Which o ring material is best for hydraulics? #2
I would think just the standard nitrile rubber ie buna-n.
/ Which o ring material is best for hydraulics? #3
Buna bounces,viton does not:
Simple test, need metal rod about 12" or so, or something similar,brass,copper,etc. Put o-ring in question under one end of rod pin the other end down with your finger raise end over o-ring then let it drop if it bounces it's buna,if it hits with a dead thud it's viton.
/ Which o ring material is best for hydraulics? #4
Thanks for that, but not what he was asking.
LOL, it's all good.
I ended up using the Viton, I've had the traditional rubber fail twice here so I figured I'd try something different. We'll see how it holds up over time.
/ Which o ring material is best for hydraulics? #6
McMaster-Carr chart; the temp difference may cause the Viton to be slightly more robust, I would think.
/ Which o ring material is best for hydraulics? #7
What is the application? Viton will with stand higher temperatures and different fluids than nitrile or Buna - N. Seal failure is usually a result of their being to large of a gap between metal mating surfaces not the seal material itself.
/ Which o ring material is best for hydraulics? #8
If you think Viton is expensive price out a compound like Kalrez. I would go Viton over rubber everytime when dealing with hydraulics. Rubber breaks down much quicker.
(INOP) BROCE BW260 SWEEPER (A62129)
(INOP) BROCE BW260...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
1995 John Deere 7400 (A60462)
1995 John Deere...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
1952 Army Jeep M38 (A61166)
1952 Army Jeep M38...
UNUSED 2026 INDUSTRIAS AMERICA 7014R 7'X14' DUMP T (A62130)
UNUSED 2026...
