Which o ring material is best for hydraulics?
/ Which o ring material is best for hydraulics? #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
I need to replace an o ring on my hydraulic system and have both rubber and viton (fluorocarbon) on hand. Which is better for this application? I'm leaning towards the viton this time. They're $$$$ but, I've already got them.
/ Which o ring material is best for hydraulics? #2
I would think just the standard nitrile rubber ie buna-n.
/ Which o ring material is best for hydraulics? #3
Buna bounces,viton does not:
Simple test, need metal rod about 12" or so, or something similar,brass,copper,etc. Put o-ring in question under one end of rod pin the other end down with your finger raise end over o-ring then let it drop if it bounces it's buna,if it hits with a dead thud it's viton.
/ Which o ring material is best for hydraulics? #4
Thanks for that, but not what he was asking.
LOL, it's all good.
I ended up using the Viton, I've had the traditional rubber fail twice here so I figured I'd try something different. We'll see how it holds up over time.
/ Which o ring material is best for hydraulics? #6
McMaster-Carr chart; the temp difference may cause the Viton to be slightly more robust, I would think.
/ Which o ring material is best for hydraulics? #7
What is the application? Viton will with stand higher temperatures and different fluids than nitrile or Buna - N. Seal failure is usually a result of their being to large of a gap between metal mating surfaces not the seal material itself.
/ Which o ring material is best for hydraulics? #8
If you think Viton is expensive price out a compound like Kalrez. I would go Viton over rubber everytime when dealing with hydraulics. Rubber breaks down much quicker.
1948 Willys CJ2A Jeep (A61166)
1948 Willys CJ2A...
UNUSED WOLVERINE TR-26-01C 3PT QUICK HITCH (A62131)
UNUSED WOLVERINE...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
INOP/NON-RUNNING 2006 Freightliner M2 106 Day Cab Truck, VIN # 1FUBCXDC06HW03952 (A61165)
INOP/NON-RUNNING...
UNUSED KJ HD 5'HX5.6'L WIRE MESH (3 PANELS) (A62131)
UNUSED KJ HD...
Willmar 4550 Wrangler Articulating Loader (A63118)
Willmar 4550...
