Swimming Pool options
/ Swimming Pool options #103
generator up front cost. generator up keep cost. more electricity use. more pump parts / maintenance ?, salt cost. and if the water does get out of whack ????? Cheaper to operate salt ?
HUMMMMMM..Maybe he doesn't know as much as you about pools, but he's still in business and still installing pools.
I would think he knows a wee bit more than the novice pool user /owner.
As for myself. I have now owned a pool for 20+ years and have never had issues using chlorine. It always has kept my water clear and clean with little effort
I was talking about chemical costs, not hardware and electricity.
I've run chlorine, baquacil, chlorine again, and then salt. Baquacil is the most expensive for chemicals. Chlorine is way less expensive. Salt costs the least overall. That's just the way it is.
/ Swimming Pool options #104
And why did you edit my quote in your reply? I never wrote those last two sentences, you did.
/ Swimming Pool options #105
Not everyone is a multimillionaire. Your annual electric bill is likely considerably more than I paid for my house and property.
There are other options.
/ Swimming Pool options #106
I use to have a hot tub and used bromine. When I got out it was very itchy on my skin. My skin has never been itchy, or had funny feeling on my skin with chlorine.
Reason I always stayed with chlorine is..A local guy that has installed inground pools for about 50 years told me once, that he only recommends chlorine, even though he would make more money selling the chemicals and generator, etc, for the salt system.
He also said that the salt was worse on pump seals than chlorine.
Well the SWG is a one time purchase 500 or 600 hundred up to a couple grand depending on your situation... other chemicals are almost nil, WAY easier and cheaper than chlorine all the time. I've done both.
Do you do powdered or pill Chlorine, or just liquid? I do liquid chlorine in my hot tub, only other thing I have to add is liquid muriatic acid on occasion.
/ Swimming Pool options #107
What generator upkeep costs? Why more pump parts/maintenance ? Salt cost might be 50 bucks a year if we have a lot of rain. I've had no generator upkeep costs or any parts or maintenance costs on my pump at all... maybe he sold you a line.. and lots of chlorine.
/ Swimming Pool options #108
I live in South Florida. A few pools down here.
A lot of people are going to salt generators because of different factors. It feels much better on the skin, it's much easier on the eyes and it's less expensive.
I would vote for salt but everybody's different. Just keep in mind, there are chemicals in those chlorine tablets that aren't produced by your salt generator. If possible, I'd rig a system where I could put a pool tablet in every now and then. Or at least put tablets in a cage.
The Sun down here eats chlorine for breakfast.
My neighbor had his pool set up for chlorine when it was built but put a salt generator in-line and uses that mostly. He got into trouble a little bit in the beginning for not using tablets once in a while. Some people just dont listen.
If it gets out of whack, you just take a gallon of chlorine and walk around the outside of the pool while pouring it in.
Either way is fine. I just like salt better. It feels better.
And salt and chlorine are essentially the same. I don't know where peeps are coming up with more corrosion from salt. nonsense. Chlorine is one of the most corrosive substances known. Actually started out as a weapon, didn't it?
/ Swimming Pool options #109
My SWG was $129! :ROFLMAO: It's from an Intex inflatable pool, adapted to my needs. I'm looking for another one now, but they are now closer to $300. At that price, I'll put the $300 towards a better unit.
/ Swimming Pool options #110
Yeah the main extra ingredient is CYA or cyuranic acid (no clue on correct spelling) I keep a bucket of the 3" tabs for just that reason and for wintertime when the SWG quits producing chlorine.
/ Swimming Pool options #111
Our pool is only open about 4 months maximum each year. In fall, we drain it down about a foot to just below the skimmer and return, dump in 6 bottles of bleach or pool sanitizer, depending on what's on sale, a bit of algaecide, and put the cover on. We never add anything over the winter. In spring, 8 months later, we remove the cover, top off the water, ad 2 bags of salt (about $10-$12), a couple gallons of bleach or sanitizer, some CYA, some algaecide, and go swimming.
Once a week I check the levels of chlorine to make sure the SWG is functioning correctly, and add a dose of algaecide. And that's about it for the rest of the summer. No additional chemicals are added except algaecide, unless we have a rain event that overflows the pool, or a dead animal, or, as I've mentioned before.... the dreaded infant in a diaper! TERROR!!! o_O
/ Swimming Pool options #114
My pool is up and running all year, only warm enough to swim maybe June to September, we closed it up the first year and didn't think it was worth the hassle. The only time I seem to get any algae is in October for what ever reason, and the only time I use algicide. As long as my water temp is over 55 my SWG does its job, when it is not I feed it the chlorine pills.
Oh, and as of yet I have not had any kids in it...
/ Swimming Pool options #115
How many gallons is your pool?
/ Swimming Pool options #117
Ours freezes solid for several months. And the leaves in fall, yikes. As soon as I see leaves turning we start closing up.
/ Swimming Pool options #118
never bought chlorine from him.. He's been in the pool business for over 50 yrs. I don't know what up keep he was talking about. It uses some type wear parts if it has to have electricity to operate
/ Swimming Pool options #119
I see what you're talking about .. I didn't edit it. I don't know how my reply got in your quote.
I'm still learning the way the site has changed.
I have to log in each time I visit the page.
I haven't been on long enough to navigate the page..
/ Swimming Pool options #120
I've never noticed my salt water pool drawing that much current. There've been times I've had the pump off for a couple of weeks with no noticeable reduction in my bill, though my bill is large for other reasons. Now turning on the air conditioner, _that_ jack up the bill quickly. But the pool chlorinator? Not so much.
2017 Crane Carrier Co. T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
Tarter 3pt 4' Rotary Mower (A64911)
Tarter 3pt 4'...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2017 Autocar...
2012 Gillig G27B102N4 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
2015 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
