3-Point Hitch 3pt hitch arm extension
/ 3pt hitch arm extension #1
Swanover
International 484
Need to extend 3pt hitch arms on my 80's IH 484 to accommodate extended pto shaft. Anyone have any experience or suggestions????
/ 3pt hitch arm extension #2
It would be a lot cheaper and easier to just shorten the PTO shaft or purchase a new one. You do know PTO shafts slide in and out, right?
/ 3pt hitch arm extension #3
The implement PTO shaft must be free to lengthen and contract to compensate for tractor moving over high (lengthen) and low (contract) points in the ground.
If the PTO shaft is NOT sliding reasonably free you need to soak it with spray "Blaster" solvent for a few days, then pull it apart, clean, remove any rust and lubricate it. Then check to see if it lengthens and contracts reasonably easy.
If the PTO shaft is sliding reasonably free and is still too long, the PTO shaft needs to be permanently shortened. See videos.
VIDEOS: https://www.youtube.com/results?search_query=cut+tractor+PTO+shaft
My problem is that the tractor does not have integral hydraulics so when I mounted a front end loader the only way I could operate it was with a PTO pump. Great but every time I wanted to use the pto [ tiller etc.] I had to pull the pump and block up the loader so it wouldn't just drag on the ground. I found a 9 inch pto shaft extension that slides over the existing shaft. Now I can leave the pump attached but the end of the pto shaft is too close to the implements to connect. I figured by lengthening the 3-pt arms I may gain the needed distance from the pto shaft to the implement.
/ 3pt hitch arm extension #6
You could add a quick hitch.
Bruce
/ 3pt hitch arm extension #7
Many years ago I see some draught arms that were in two parts with holes drilled at equal lengths along each part. The farmer would undo a couple of nuts and bolts, select what length he wanted and find two suitable holes to put the bolts back in. But as I said at the start, I`ve not seen any of these for years.
Unfamiliar with quick hitch.
/ 3pt hitch arm extension #11
/ 3pt hitch arm extension #12
There is something called "Pats", that is a quick hitch type of deal that lengthens the lower links about 6 inches. My father in law had one on his little Kubota and it seems to work pretty good. That might work for you and I don't think it is very expensive.
/ 3pt hitch arm extension #13
Let's go back to "why can't you cut down the pto shaft?" The are made to cut down for your specific needs.
The idea of using a quick hitch is also good. It will add maybe 4" to effective lift arm length. If you use many attachments, it could also make hooking up more convenient (which is its primary purpose).
/ 3pt hitch arm extension #14
Rather than mess with the 3 point arms you could plumb your loader into the 484 tractor hydraulics rather than use a PTO pump.
/ 3pt hitch arm extension #16
KUBOTA L2501 TRACTOR (A62130)
KUBOTA L2501...
43018CFL (A59228)
43018CFL (A59228)
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2015 John Deere R4038 Sprayer (A63109)
2015 John Deere...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
