Concrete Ballast box
/ Concrete Ballast box #1
nato674
Allgomera NSW
Kubota m7040
Hi everyone. Wondering if anyone knows how to calculate the measurements to make a box of concrete to around the 700lb mark?
Nathan
/ Concrete Ballast box #2
These are approximate numbers based on typical sack mix:
Concrete dry mix density is about 162-164 lb/cu.ft (not counting air).
Cured density is about 145 lb/cu.ft
For 700# of cured concrete, you will need about 4.8 cu.ft of volume.
/ Concrete Ballast box #3
Nathan
2 foot x 2 foot x 14 inches will get you 700 lbs. Do a quick net search for concrete slab weight and you will be able to find a calculator to plug your dimensions into to come up with the weight you need.
Length(feet)x width(feet)x thickness(inches)/12x 150= weight in pounds. Approx 150 lbs per cubic foot. Hope this helps.
/ Concrete Ballast box #4
Numbers I used was 150 pounds per cubic foot, so my 2x2x1 steel box is 4 cubic ft and should be right at 600 lbs...
Handy Concrete Weight Calculator | Dumpsters.com
Spray can caps cover 2 inch ABS pipes for tool holders...
Dale
/ Concrete Ballast box #6
Be mindful of too much weight out back.
I put on the "big ballast" out back (650#), and broke the front axle casting while digging stumps using curl on the loader.
With a lesser rear weight, the rear end lifted before the "CRACK".
Oh well, a $thousand here, a $thousand there. Live and learn.
/ Concrete Ballast box #7
Ow! ow! ow!
I put an 800# ballast on back, and wouldn't have hesitated to curl the loader working on a stump (though I haven't happened to do it yet). I don't want that to happen to my machine -- what tractor did this happen to, if I can ask?
/ Concrete Ballast box #8
On what? A Kubota B7200?
Ow! ow! ow!
Again - on what?
My preferred ballast for my B7810 is a 850 lb backhoe.
/ Concrete Ballast box #9
Hurlimann 435
/ Concrete Ballast box #10
Nathan
There are differing weight ratings for concrete. A generally accepted weight is around 150lbs per cubic foot of dry concrete.
To achieve your 700lbs desired weight, you need approximately 4 2/3 cubic ft. This weight factor will be influenced by the amount of steel you add to the mix. The 4 2/3 cu ft is raw concrete weight.
The size of your frame is conditional upon how you want the box to sit on the back of your tractor.
Do you want it to set as much as possible inside your lower arms? Or the opposite, as much as possible behind your lower arms? Do you want tubes within the ballast to hold tools (shovels, rakes, chains, chainsaw, whatever)?
2020 International HX620 Quint Dump (A62613)
2020 International...
UNUSED WOLVERINE HYD SNOW PUSHER (A64281)
UNUSED WOLVERINE...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
2024 SCAG SCZ61V Cheetah 60in Zero Turn Mower (A61572)
2024 SCAG SCZ61V...
