Sick of cheap box store riding mowers. 1500-3k budget used zero turns?
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #1
p0opstlnksal0t
Eliot, Maine
in the market
Looking at a couple high-end older used mowers. I'm on my second Craftsman t3000 which has been junk. Am I better off with one of these older far superior-made machines?
The g1800 is 2500 bucks, the t1870 is 1800 and the Honda is 1,100. I also found a simplicity zero turn for $1800 that looks like it's not too bad
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #2
Have you checked out the cub cadet? 54 inch deck
about $2000?
willy
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #3
View attachment 699117View attachment 699118View attachment 699119
I would run from the Honda...
still have that models big brother (4518h). it sits in pieces. hydro jerks back and forth, that's when it would run...
Ignition problems, charging problems, starting problems, PTO clutch problems
parts are $$$
I have had much better service from my Hydro MTD that has the Peerless/ Eaton hydrostat, still smooth as silk with 35 years of use.
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #5
Many, many years ago - I gave up on box store mowers. My "old" mower is a Kubota G100. I use it for the REALLY tough cutting. Wild rose bushes, buck brush and mowing the field grass in newly opened meadows. My new mower is a Kubota X570. I mow two acres of "grass". About one and a half acres is meadow. Keep it mowed and after a couple years it will look, almost, like a real lawn. All the lawn provides a fire break around the house and outbuildings. This is a meadow I just opened up last year. Sure looks smooth in this picture. Well, it's not. Like most of my lawn - 2 to 3 mph is max.
about $2000?
willy
I saw them in Lowe's or home Depot I can't remember honestly wasn't impressed didn't seem any better than the Craftsman or Husqvarna that was in there.
/ Sick of cheap box store riding mowers. 1500-3k budget used zero turns? #7
I would look for a used Simplicity Conquest if you can find one. I had one for 4 years and traded on a Ventrac
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
(INOP) 2004 INTERNATIONAL 4300 SBA TRUCK (A59823)
(INOP) 2004...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2017 Volkswagon Passat Sedan (A59231)
2017 Volkswagon...
