John Deere 4600 Knocking? Need help
/ John Deere 4600 Knocking? Need help #1
Mrmoo
John Deere 4600
Hey everyone,
So I might have bit off a bit more than I can chew with this project. I am not a mechanic and have never worked on a diesel motor but consider myself handy. I have a JD 4600. When I first bought it, it seemed ok. Not great but ok. As a few weeks passed, it started getting a ton of white smoke and oil coming from the breather tube.
So i tore into the motor and found the piston ings stuck on one piston and the piston ring and piston groove broken on the #4 piston. The cylinder didn't look bad at all. I assume the previous owner used starting fluid which I'm told is a no no. So I put all new pistons and rings in and new head gasket. I get everything back together and it's making this noise. Not sure what it is and need advice before I take everything back apart. The picture is what the oil looks like when i drained it.
Video
/ John Deere 4600 Knocking? Need help #2
I’m not sure what the picture is?? In the video I couldn’t hear any unusual knocking, they make stethoscopes for mechanics, you can use that to pin it down to a particular area of the engine.
/ John Deere 4600 Knocking? Need help #3
A wooden dowel rod held to one's ear makes a cheap tractor/equipment stethoscope.
/ John Deere 4600 Knocking? Need help #4
Hey everyone,
Video
What came of it? What did you find?
/ John Deere 4600 Knocking? Need help #5
Is the knocking in the lower end or up by the valve train? Could need a simple valve adjustment.
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
