eMax 26L Loader SS Quick Hitch Adapter
/ eMax 26L Loader SS Quick Hitch Adapter #1
rdinatal
Gold Member
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
Has anyone changed the eMax factory 26L 'pin on bucket' to a Skid Steer Quick Hitch?
What brand did you go with?
Happy, sad, should have done different??
No one has done this?
/ eMax 26L Loader SS Quick Hitch Adapter #3
I did do this two years ago with my eMax 25. Can't remember which brand my dealer set me up with. Will look tomorrow and reply. It works well and glad I did it. Did loose a little curl. When the bucket is level on flat ground there is very little curl available on my setup. Quickly got used to it and has not been a problem.
/ eMax 26L Loader SS Quick Hitch Adapter #5
Quick Hitch is for the 3 point:
Quick Attach is for the loader:
:unsure:
@Xfaxman, thanks for the correction but are you able to contribute to answer my question?
/ eMax 26L Loader SS Quick Hitch Adapter #7
:unsure:
The question is:
The answer is: No, my machine came with a Quick Attach
/ eMax 26L Loader SS Quick Hitch Adapter #8
Hi rdinatal, the adaptor my dealer provided is a Worksaver Item# 835140, McCormic 125c Adaptor to ss with pins. My eMax has the two hydraulic cylinders, thus the McCormic style. If you have the single cylinder, it is listed under subcompact Mahindra.
Thanks, mine also has the two hydraulic cylinders. This is a start!
/ eMax 26L Loader SS Quick Hitch Adapter #12
Moved up to a Max 26xl...
Problem solved.
i thought it wasnt till 18 that it got the ssqa along with the fender control and better seat?
i still have a pin on bucket and mine is 15
Your are correct on the eMax 25 upgrades. Mine was a '15 also.
Very big difference between the eMax 25 and the Max 26xl. Not just the capacity but the physical size.
/ eMax 26L Loader SS Quick Hitch Adapter #14
i was talking about the Max, I own a Max
DRAGON 500 BBL FRAC TANK (A67714)
DRAGON 500 BBL...
2012 INTERNATIONAL PROSTAR+ 122 6X4 ROAD TRACTOR (A65054)
2012 INTERNATIONAL...
2025 Wolverine GB-11-72W 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A66734)
2025 Wolverine...
Unused Hustler DG LM200 SS 79in Hydraulic Dual Cylinder Grapple Loader Tractor Attachment (A66734)
Unused Hustler DG...
4' Single Drum Roller (A64912)
4' Single Drum...
18 FOOT WATER/FUEL TRAILER (A67714)
18 FOOT WATER/FUEL...
