eMax 26L Loader SS Quick Hitch Adapter
   / eMax 26L Loader SS Quick Hitch Adapter #1
rdinatal
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
Has anyone changed the eMax factory 26L 'pin on bucket' to a Skid Steer Quick Hitch?
What brand did you go with?
Happy, sad, should have done different??
No one has done this?
   / eMax 26L Loader SS Quick Hitch Adapter #3
I did do this two years ago with my eMax 25. Can't remember which brand my dealer set me up with. Will look tomorrow and reply. It works well and glad I did it. Did loose a little curl. When the bucket is level on flat ground there is very little curl available on my setup. Quickly got used to it and has not been a problem.
   / eMax 26L Loader SS Quick Hitch Adapter #5
Quick Hitch is for the 3 point:
Quick Attach is for the loader:
:unsure:
@Xfaxman, thanks for the correction but are you able to contribute to answer my question?
   / eMax 26L Loader SS Quick Hitch Adapter #7
:unsure:
The question is:
The answer is: No, my machine came with a Quick Attach
   / eMax 26L Loader SS Quick Hitch Adapter #8
Hi rdinatal, the adaptor my dealer provided is a Worksaver Item# 835140, McCormic 125c Adaptor to ss with pins. My eMax has the two hydraulic cylinders, thus the McCormic style. If you have the single cylinder, it is listed under subcompact Mahindra.
Thanks, mine also has the two hydraulic cylinders. This is a start!
Moved up to a Max 26xl...
Problem solved.
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A55745)
2014 AMERITRAIL...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2023 Bobcat S76 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50775)
2023 Bobcat S76...
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
