Best Steering / Frame / Tractor Combo -- for Robotic-Electric.
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #1
Phil Timmons
Any bright thought about the best Steering / Tractor combo . . . or maybe even the other direction -- the Do Nots for these . . .
For a sort of Robotic / Autonomous / Semi-Autonomous field tractor rig?
Figure this will be Electric, All-Wheel Drive. Small battery for general mobility, and then Cord-Connected when it is time to get-to-work.
The sketch below covers the general options. The skid steer could also be a "track." (Skid Steer works with just rights or just left wheels turning. Sometimes one side forward and one backward for zero radius turn).
I guess they missed the Zero Turn mower style. Suppose I should include that. Well, cannot find a decent sketch. I guess you know how those work? Two forward-reverse drive wheels, along with "dumb" caster wheels, up front.
So which is better or best and why?
Thanks!
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #2
All of them obviously.
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #3
#3 will give the best turning radius without whipping the loader or other fixed attachment the way an articulated design does.
I figured #2 was the weird one, until I considered that is how every (?) Combine works.
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #5
What tasks and terrain are you planning? Each design has pros and cons depending on the task, terrain, space available, machine weight, horsepower, etc.
Really good point -- let the task(s) direct the methods? Maybe throw cost at some level in there, too.
For example, the Zero Turn Mower style is cheapest, and I suppose the 4 wheel drive + 4 wheel independent steering is the most expensive.
My intended use is typical crop-veggie farming. But probably without the need for huge drawbar capacity (like a typical plow, as it were) in favor of large(r) scale rototilling.
So that is probably:
1. Seed Bed (rototill, again),
2. Planter,
3. Various harvester add-ons, and
4. Shuttle-transport, I suppose.
Have considered underslung rototiller -- down between the wheels, at it were. But could also be tow-behind.
Full fantasy would also handle an auger (mid-mount or behind, dunno, yet) and trencher / mini-backhoe -- all for Solar Projects.
Another thing towards task -- light weight. At least compared to a typical tractor. So this thing can load up easy on a 1/2 ton pickup truck, rather than maxing out a three-axle gooseneck. ;)
As far as Horsey Power -- probably well under 100 HP (100kW -- for everything -- drive motor(s), attachments, even lights). Would probably want under 50 HP for the first prototype. (50kW, because a cheap standard 250V 200 Amp single phase service can source that).
Thanks. I tend to think of that style as something of a "tugger" -- like the various tractors move jets around an airport.
One key feature I am trying to get onto this is a cord -- so the battery can stay small, and pretty much just to be used to move itself, or may tow a "lite" something, about like that mover -- battery small, and still allow the thing some serious firepower when it gets to work with real power from the cord.
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #12
PowerTrac PT425
Articulated loader
800# lift
1500# machine
All attachments on the FEL arms.
Tiller, post hole auger, planter auger, forks, trailer mover, mini-ho, trenchers, over 40 attachments.
Quick attach and FEL arms included in price.
Fits in the bed of a standard pickup with an attachment.
Someone already converted one to battery power.
There are threads about it here on TBN.
PowerTrac PT425
Articulated loader
800# lift
1500# machine
ahhh. That is what you have in your picture. But that makes sense as that is what is listed in your type. (duh, huh? ;) )
These do not exist as standard product Electric? (yet ;) )
and here is the retro? Electric Drive Motor Retrofit
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #14
I would think zero turn would be the cheapest and easiest. And the lightest weight. Depending on how fancy you wanted to go a single axle with open diff and brakes on each side for turning would work for a prototype. I think that is how the Tamiya RC tanks used to work. Gearbox driving both rear wheels with the steering done by a brake on each side. May have been for scale realism but I haven't read the blurb for a while and never owned one.
Might be worth going to wet brakes to keep the wear under control on something bigger.
James
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #15
Light weight might be beneficial for a lawn or field mower, but traction is a key attribute for a multi-purpose tractor.
Light weight is less efficient for ground engagement tasks.
Also wondering about the real life usability of being tied to an umbilical cord for power.
Compare the use of a traditional vacuum cleaner vs a free roaming Roomba style vacuum - dragging a cord over a carpet is exponentially easier than dragging a cord around a field, or even a golf course smooth lawn. Add one obstacle (a gate, a shrub or tree) to maneuver around and you're done.
An alternative is use of external add-on battery power packs.
Design attachable large battery packs for work activities. Large battery packs would also work to replace ballast for weight...(replace the ballast box with battery power).
Design them to be fast charging...and fast changing...simply back up to it, auto connect and go.
Provide limited battery power native on the tractor to maneuver without the external battery packs while hooking and unhooking to the large power packs.
James
Thanks. Yes, Zero Turn is appealing on the low dollar aspect. And it suppose it handles well.
Since I am looking at doing full automation, and Zero Turn also controls and behaves well for automation.
With Full Electric drive the braking becomes sort of eas(ier) -- I can use re-generative braking where the motor to be slowed becomes a generator with a load, so it slows it down rapidly, (and can even stop and hold a load) before a mechanical brake even engages. When we do that for overhead cranes, the mechanical usually waits for the load to stop, and then locks onto the drive shaft of the motor. I use the re-gen braking on my Volt (Chevy car that has electric drive + a gasoline engine generator), and with over 100K miles, the mechanical disc brakes are not even worn.
It is often a little too easy to pile weight on. For humans and mobile equipment. ;)
In this case, light weight is desirable for mobility between sites. Sort of funny but for things we need to add weight to -- like Solar PV, so it does not blow away -- we will sometimes use what are called "Ballast" systems -- concrete blocks, intentionally placed on a commercial ROOF, (sounds crazy, huh?) just to create dead weight. Looking at some designs to use water tanks for the same.
The Cord thing is mostly an interest of mine, but it becomes so much cheaper than a battery system, you could sort of consume or "burn through" some cords as an operating expense as it just part of the process.
The important part is what might be called "Cord Management" (for lack of a better term). Cord Management sort of being a planned way to deal with obstacles, not running over the cord, and minimized wear and damage to the cord. I have been running some small tests, and it seems like a do-able thing. This is sort of assuming that Grid Power is available at or near the work site, or can be easily added. And like you noted, if this is not so great, one can add batteries, later.
There is a discussion thread I started last week on that . . . here >>> Cord Management on Grid-Connected Electric Tractors and Mobile Equipment
Here is the First Draft on Zero Turn.
Comments, Suggestions, OMGs all welcome.
Here are some notes ==
+ Steering Caster may be too much -- maybe more vertical?
+ Drawn with 20 inch tires. Frame is spaced to handle up to 24 inches.
+ Drawn with 1:5 Sprocket Ratio == motor nominal RPM is 1200 RPM.
+ Bigger tires may be better -- however, the larger the diameter, the more I have to gear down the sprockets.
+ Maybe the Drive Wheels should be "Front?" Lets it climb over things easier.
+ Over all dimensions are just what turned out. Trying to keep width under 3 feet to let it get through narrow paths, doorway, gates, etc. Could cut length down to 4 feet -- just trying to prevent it from flipping backwards with a pulling load.
Add on Edit -- Brakes. I am planning on using VFDs as load regeneration to stop either or both motors -- BUT -- I see I still need Emergency and Parking Brake(s). Looks like the left and right split axles may be the place to put those.
Next up . . . .
So that last one was the Zero Turn.
This one is the Articulated (Folding or Hinged) Frame.
Still has (2) Drive Motors -- but now is 4 Wheel Drive. That seems like quite a productive improvement.
Adds a Steering Linear Actuator -- sort of works like a two-way piston -- but that also means I can lose the Steering Casters.
Did two rough designs -- a sort of "long" one, based on a portion of the Zero Turn frame and motor mount, and a "short" design that comes closer to a model of a mini-front-end-loader.
As with the Zero Turn, I need to add Emergency and Parking Brakes, which can mount on the solid side-to-side drive axles -- which have more room to work than with Zero Turn split axles.
The center pivot and bearings, I have not done any real details on yet, and the same lack with the Steering Linear Actuator. I think some designs use (2) single action pistons (?). Dunno, will have to study the State of the Art and Best Practices a bit more.
Again, any comments, edits, suggest, or cautions are welcome.
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #20
What about differentials on the articulated design?
2019 GALYEAN...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2016 FORD F-450 (A60736)
2016 FORD F-450...
2025 Pabreak Hydraulic Vibratory Plate Compactor Skid Steer Attachment (A61567)
2025 Pabreak...
2017 PETERBILT 389(INOPERABLE) (A60736)
2017 PETERBILT...
THUNDER CREEK 460 GALLON FUEL TRAILER (A60736)
THUNDER CREEK 460...
