Best Steering / Frame / Tractor Combo -- for Robotic-Electric.
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #1
Phil Timmons
Any bright thought about the best Steering / Tractor combo . . . or maybe even the other direction -- the Do Nots for these . . .
For a sort of Robotic / Autonomous / Semi-Autonomous field tractor rig?
Figure this will be Electric, All-Wheel Drive. Small battery for general mobility, and then Cord-Connected when it is time to get-to-work.
The sketch below covers the general options. The skid steer could also be a "track." (Skid Steer works with just rights or just left wheels turning. Sometimes one side forward and one backward for zero radius turn).
I guess they missed the Zero Turn mower style. Suppose I should include that. Well, cannot find a decent sketch. I guess you know how those work? Two forward-reverse drive wheels, along with "dumb" caster wheels, up front.
So which is better or best and why?
Thanks!
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #2
All of them obviously.
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #3
#3 will give the best turning radius without whipping the loader or other fixed attachment the way an articulated design does.
I figured #2 was the weird one, until I considered that is how every (?) Combine works.
/ Best Steering / Frame / Tractor Combo -- for Robotic-Electric. #5
What tasks and terrain are you planning? Each design has pros and cons depending on the task, terrain, space available, machine weight, horsepower, etc.
Really good point -- let the task(s) direct the methods? Maybe throw cost at some level in there, too.
For example, the Zero Turn Mower style is cheapest, and I suppose the 4 wheel drive + 4 wheel independent steering is the most expensive.
My intended use is typical crop-veggie farming. But probably without the need for huge drawbar capacity (like a typical plow, as it were) in favor of large(r) scale rototilling.
So that is probably:
1. Seed Bed (rototill, again),
2. Planter,
3. Various harvester add-ons, and
4. Shuttle-transport, I suppose.
Have considered underslung rototiller -- down between the wheels, at it were. But could also be tow-behind.
Full fantasy would also handle an auger (mid-mount or behind, dunno, yet) and trencher / mini-backhoe -- all for Solar Projects.
Another thing towards task -- light weight. At least compared to a typical tractor. So this thing can load up easy on a 1/2 ton pickup truck, rather than maxing out a three-axle gooseneck. ;)
As far as Horsey Power -- probably well under 100 HP (100kW -- for everything -- drive motor(s), attachments, even lights). Would probably want under 50 HP for the first prototype. (50kW, because a cheap standard 250V 200 Amp single phase service can source that).
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2016 Yanmar Vio25 (A60462)
2016 Yanmar Vio25...
1991 FORD F-800 BED TRUCK (A60736)
1991 FORD F-800...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
