Honey Locust Tree
/ Honey Locust Tree #41
I have hundreds of them at my farm i girdle and spray with tordon, It will kill them , I tried gordon stump killer and got poor results. My neighbor 3 weeks ago had an acre or so cleared of locust and cedar, Guy pulled them up with an excavator while his son used a grapple on a skid steer to pile them up. Charged him 850 bucks.
/ Honey Locust Tree #42
U.S. champion honey locust tree is 103' tall, 112' crown spread, and 247" circumference! Yikes! That's about a 6.5' diameter. Freak? Probably, but wow.
/ Honey Locust Tree
OMG!!!
We could make a horror movie - Godzilla and Kong v. the giant Honey Locust!!
My money is on the thorned monster!
MoKelly
/ Honey Locust Tree
Well - who could of guessed.
I got a flat in my front tire.
Plugged the hole. But - it still very slowly looses air. It goes from 20 psi to 15 psi over 8 days.
I cannot find where it’s leaking. I took the tire off, washed it completely, fully dried and then sprayed the whole thing looking for leaks. Can’t see one air bubble. I even sprayed the rims snd stem.
I guess filling it each time I use it can work - but I’d like to find the leak.
Any suggestions?
MoKelly
/ Honey Locust Tree #45
Going to need a fair amount of soapy water and patience. A leak that slow will be hard to detect and will look like a small cluster of very small bubbles.
/ Honey Locust Tree #47
You might have a secound thorn that only leaks or leaks worse while tire is moving and flexing.
/ Honey Locust Tree #48
X2 on the idea of @jaxs. I had one on my pickup like that and the final analysis was just old age leaking through the rubber. The tire shop that I took it to couldn't find it either.
All the best,
Peter
/ Honey Locust Tree #49
Thanks. That is what I feared. I was hoping for some miracle.
John
A leak that slow you may want to give the green slime tire sealant a try
/ Honey Locust Tree #50
The folks in the PowerTrac forum highly recommend Gempler's tire sealant. Might want to ask over there and see how they like it.
/ Honey Locust Tree #51
Any suggestions?
MoKelly
Ever thought about foaming the tires fore weight? No leaks anymore, I heard.
/ Honey Locust Tree
On all their products, Gempler says it’s designed for prevention - not to repair existing leaks.
Not sure what that means.
MoKelly
/ Honey Locust Tree #54
Folks at tire repair shops don't think much of any brand sealant.
/ Honey Locust Tree #55
Ironic there's a cemetery adjacent to it. Maybe those folks tried to climb the tree then paid the price!? 🧗‍♂️
/ Honey Locust Tree
I filled the tire up yesterday and mowed for around 3 hours. Put everything away and went inside.
Today I measured the pressure and it went down only 1psi.
At that rate, I’m just going to let it be and fill the tire every 5-6 days.
I don’t want to use the slime or anything inside the tire quite yet as, like some have said, tire places hate it and if I get a larger leak my tire place is pretty good and cheap.
One of my mowers has a slow leak and I just fill the tire before each use. Sort of red neck I know but it works.
MoKelly
/ Honey Locust Tree #58
Any suggestions?
MoKelly
Not sure what size your fronts are? If 16" or less, slime it and move on.
/ Honey Locust Tree #59
MoKelly
Sorry, I should have read down.
If it doesn't bother you to have to air up a tire once a week, go for it.
/ Honey Locust Tree
Yesterday was a very nice day - full sun and great temps. I mowed a little with the tractor. Came back to the garage and washed it off a tad.
While I was cleaning a few places with windex, I decided to try to find the slow leak in the front left tire.
Well I found it. A very very slight bubbling of air right in the middle of the tread. The sunlight was perfect to see the few bubbles.
So, I plugged it. No air bubbles after the plug was in.
There could be another leak somewhere but I’m feeling optimistic.
We will see if I lose any air pressure next time I’m at the farm.
MoKelly
John Deere TX Gator (A60462)
John Deere TX...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
2021 Exmark Lazer Z 60in. Commercial Zero Turn Mower (A61572)
2021 Exmark Lazer...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
2010 INTERNATIONAL PROSTAR PREMIUM ROAD TRACTOR (A63291)
2010 INTERNATIONAL...
