Ash Trees Dying
/ Ash Trees Dying #1
HawkinsHollow
Veteran Member
SE TN
Branson 3015R
I have a handful of ash trees on my property. I noticed over the last couple of weeks they don't look so good. I wonder if I have Emerald Ash Borers killing them off. This has just happened over the last year I'd say. I had a nice sized Ash that is looking a little pitiful and a few smaller ones that appear to be completely dead. I just did a little research on how to tell and will try to probe deeper to see if that could be a cause. My question is: what next? Should I just use the wood for firewood? Is it best to just pile them up and burn them all at once? My property is in extreme North Georgia, I didn't think this was going to be an issue this far south so soon.
/ Ash Trees Dying #2
I have lost dozens of Ash trees from small 20' to ones over 100' tall.
If it's EAB (most likely) then you will see holes in the bark shaped like a D.
Be careful, as they die they get brittle and become very dangerous.
I use the dead ones for firewood and some simple slab milling.
Makes good firewood (ash!)
These bugs are everywhere, sorry you have to deal with them too. By the time you see them dying they are probably in most of the trees. I tried to treat one, but it was too late.
/ Ash Trees Dying
Definitely EAB, pealed the bark back and it had the telltale sign of the little burrow paths. Sad! Guess its time for some big bonfires!
/ Ash Trees Dying #4
All the ash trees in MY area are dead. EAB got them all. Tree guys got rich off it.
/ Ash Trees Dying #5
EAB got all of my ash trees. Friends got a bunch for firewood. Enough for several families.
/ Ash Trees Dying
Yeah, I will have plenty of firewood from these trees for a while. I have a couple bigger ones I might try to get to my friends sawmill.
/ Ash Trees Dying #8
Don't know if you know where the EAB came from, but it came in here in Michigan in a ocean going ship that unloaded pallets of stuff and the pallets had the EAB in the wood.
We had 2 large ash trees in the backyard and right from the get go, I treated them with Bayer Tree and Shrub treatment (recommended to us by the county extension agent) and we managed to keep them alive when all of the other Ash trees in the county were dead, in fact the county extension agent was watching ours but eventually they succumbed to the borer and we had them cut down and yes, I roasted them in a couple big fires. Too bad really as they are nice trees or should I say, were.
/ Ash Trees Dying
Because of the EAB, we aren’t supposed to transport firewood outside the county. You are supposed to get your wood within the county you live.
Yeah, I am pretty sensitive about transporting firewood. Looks like I will have to be even more so now.
/ Ash Trees Dying #10
Looks like you have your answer. One of the big telltales I see around here as they have migrated into the region is the sprouting of new branches down low on the tree. If you see ash trees with new small branches coming out of the trunk below the main crown, odds are that is EAB. Because the leaves above are cutoff from the roots by the EAB tunneling, they start to grow new branches just below the infestation sites. It can be near ground level or anywhere above on the main stem.
I love using ash to make drawer cases as it works well and it sturdy and is reasonably cheap...well used to be. I'm guessing that won't be true anymore based on my last batch a year ago... $$$ Great firewood too, just keep it very local to help slow the spread a bit.
/ Ash Trees Dying #11
We've lost quite a few in the past couple of years.
Surprisingly I'm seeing a lot of new growth suckers on the stumps of the trees I cut down.
/ Ash Trees Dying #12
I have seen suckers pop out of 18in long bucked up firewood. Stumps all the time too. They don't seam to last to long though.
I had a bunch of ash and nearly all of it got milled up into 1x or 2x boards. I currently am making stair treads out of the 2x material for a cabin. Some day il also make the rest into a 1,000,000 floor.
/ Ash Trees Dying
I thought it was more of a northern thing until I looked at an impact map online yesterday. They have made it as far south at Atlanta. The western US has not been impacted yet but they have far fewer Ash trees.
/ Ash Trees Dying #17
It been well over five years since this EAB started here. I have been cutting these dead ash for some time. It's getting to a point that some of them are so dried up and rotten they are no good for fire wood. They will fall over and just blow apart when the hit the ground. Here are some pictures that I posted before when I repaired a Amish skidder/ new wheel bearings. Anyways that was in 2016. And that was the start of the EAB around here. My neighbor got lucky when he logged out his woods that year, because most his ash went for baseball bats. He had 53 tri-axle loads of logs taken out and like I said the majority of the ash went for baseball bats. But a large part of the remained logs, oak, beach, hemlock, etc., went into gondolas and shipped to China. How about that.
/ Ash Trees Dying #19
I lost more than 40 Ash trees this summer, they withered and died with bark pealed back and all evidence points to this summers long drought here in Texas. EAB I considered possible, but I honestly don't know the indication or what to look for to confirm it was borers.
