Honey Locust Tree
/ Honey Locust Tree #41
I have hundreds of them at my farm i girdle and spray with tordon, It will kill them , I tried gordon stump killer and got poor results. My neighbor 3 weeks ago had an acre or so cleared of locust and cedar, Guy pulled them up with an excavator while his son used a grapple on a skid steer to pile them up. Charged him 850 bucks.
/ Honey Locust Tree #42
U.S. champion honey locust tree is 103' tall, 112' crown spread, and 247" circumference! Yikes! That's about a 6.5' diameter. Freak? Probably, but wow.
/ Honey Locust Tree
OMG!!!
We could make a horror movie - Godzilla and Kong v. the giant Honey Locust!!
My money is on the thorned monster!
MoKelly
/ Honey Locust Tree
Well - who could of guessed.
I got a flat in my front tire.
Plugged the hole. But - it still very slowly looses air. It goes from 20 psi to 15 psi over 8 days.
I cannot find where it’s leaking. I took the tire off, washed it completely, fully dried and then sprayed the whole thing looking for leaks. Can’t see one air bubble. I even sprayed the rims snd stem.
I guess filling it each time I use it can work - but I’d like to find the leak.
Any suggestions?
MoKelly
/ Honey Locust Tree #45
Going to need a fair amount of soapy water and patience. A leak that slow will be hard to detect and will look like a small cluster of very small bubbles.
/ Honey Locust Tree #47
You might have a secound thorn that only leaks or leaks worse while tire is moving and flexing.
/ Honey Locust Tree #48
X2 on the idea of @jaxs. I had one on my pickup like that and the final analysis was just old age leaking through the rubber. The tire shop that I took it to couldn't find it either.
All the best,
Peter
/ Honey Locust Tree #49
Thanks. That is what I feared. I was hoping for some miracle.
John
A leak that slow you may want to give the green slime tire sealant a try
/ Honey Locust Tree #50
The folks in the PowerTrac forum highly recommend Gempler's tire sealant. Might want to ask over there and see how they like it.
/ Honey Locust Tree #51
Any suggestions?
MoKelly
Ever thought about foaming the tires fore weight? No leaks anymore, I heard.
/ Honey Locust Tree
On all their products, Gempler says it’s designed for prevention - not to repair existing leaks.
Not sure what that means.
MoKelly
/ Honey Locust Tree #54
Folks at tire repair shops don't think much of any brand sealant.
/ Honey Locust Tree #55
Ironic there's a cemetery adjacent to it. Maybe those folks tried to climb the tree then paid the price!? 🧗‍♂️
/ Honey Locust Tree
I filled the tire up yesterday and mowed for around 3 hours. Put everything away and went inside.
Today I measured the pressure and it went down only 1psi.
At that rate, I’m just going to let it be and fill the tire every 5-6 days.
I don’t want to use the slime or anything inside the tire quite yet as, like some have said, tire places hate it and if I get a larger leak my tire place is pretty good and cheap.
One of my mowers has a slow leak and I just fill the tire before each use. Sort of red neck I know but it works.
MoKelly
/ Honey Locust Tree #58
Any suggestions?
MoKelly
Not sure what size your fronts are? If 16" or less, slime it and move on.
/ Honey Locust Tree #59
MoKelly
Sorry, I should have read down.
If it doesn't bother you to have to air up a tire once a week, go for it.
/ Honey Locust Tree
Yesterday was a very nice day - full sun and great temps. I mowed a little with the tractor. Came back to the garage and washed it off a tad.
While I was cleaning a few places with windex, I decided to try to find the slow leak in the front left tire.
Well I found it. A very very slight bubbling of air right in the middle of the tread. The sunlight was perfect to see the few bubbles.
So, I plugged it. No air bubbles after the plug was in.
There could be another leak somewhere but I’m feeling optimistic.
We will see if I lose any air pressure next time I’m at the farm.
MoKelly
Dad's Garage Decorative Metal Sign (A61569)
Dad's Garage...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2016 CAT 259D Compact Track Loader (A61166)
2016 CAT 259D...
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2025 Kivel 42in Forks and Frame Skid Steer Attachment (A61567)
2025 Kivel 42in...
2025 IRET13 Electric Tricycle (A60352)
2025 IRET13...
