Howard Rotovator HN
/ Howard Rotovator HN #1
Barney6595
Grants Pass, Oregon
kubota B6100-D
I have an old "Howard Rotovator HN" that came with my B6100-D Kubota Tractor 35-40 yrs ago. I now need the small sprocket at the top of the drive chain. Large at bottom and chain are still usable. I can not find any part numbers on the sprocket. Is this sprocket available new or used? Been searching the internet but with no luck. I do have pictures and diagrams with measurements.
/ Howard Rotovator HN #2
A FORD 105 tiller is exactly the same as a Howard HN. Its known as a Howard Cadet J style tiller. Ford does show the part # in their system.
/ Howard Rotovator HN #3
IF you only replace one sprocket and use the tiller much, that sprocket won't last.
It should all be replaced as a set, as the sprockets and chain wear as a "set".
SR
SR
I know that to be true, but finding the one gear would be better than nothing. But I since I just recieved a reply letting me know where to find the part , I will replace both gears and chain.
This forum has been a real time saver. thanks
2020 KUBOTA SVL75-2 SKID STEER (A62129)
2020 KUBOTA...
2019 RoGator RG1300C Spreader (A63109)
2019 RoGator...
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2016 Ford Transit Connect Cargo Van (A61568)
2016 Ford Transit...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
