Howard Rotovator HN
   / Howard Rotovator HN #1
Barney6595
Grants Pass, Oregon
kubota B6100-D
I have an old "Howard Rotovator HN" that came with my B6100-D Kubota Tractor 35-40 yrs ago. I now need the small sprocket at the top of the drive chain. Large at bottom and chain are still usable. I can not find any part numbers on the sprocket. Is this sprocket available new or used? Been searching the internet but with no luck. I do have pictures and diagrams with measurements.
   / Howard Rotovator HN #2
A FORD 105 tiller is exactly the same as a Howard HN. Its known as a Howard Cadet J style tiller. Ford does show the part # in their system.
   / Howard Rotovator HN #3
IF you only replace one sprocket and use the tiller much, that sprocket won't last.
It should all be replaced as a set, as the sprockets and chain wear as a "set".
SR
Thank You - that's a lot of help
SR
I know that to be true, but finding the one gear would be better than nothing. But I since I just recieved a reply letting me know where to find the part , I will replace both gears and chain.
This forum has been a real time saver. thanks
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
2012 Harley-Davidson FLHX Street Glide Motorcycle (A50324)
2012...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
