3720 Compact Tractor trouble indicator
/ 3720 Compact Tractor trouble indicator #1
swswarthout
I get a flashing gear wheel with an exclamation point inside and a message saying "Err 06". What ever the error, it seems to limit my highway speed. It may limit other speeds, but generally I am in Lo range and not going fast. Any ideas? I brought it up to the dealer, but no resolution.
/ 3720 Compact Tractor trouble indicator #2
I have a 3320 and get the same code (err 06) but I only get it when decelerating after running down the road for fuel in high range. My research has turned up several suggestions that its the speed sensor. They're not expensive, I just haven't had a chance to pick one up to confirm. Might be worth a try. Mine always clears when I shut the tractor down and only reoccurs when I run for fuel again... That's why it's not a priority to me.
/ 3720 Compact Tractor trouble indicator #3
2018 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A64556)
2018 Ford F-550...
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
2004 MACK CV (GRANITE) KILL TRUCK (A65643)
2004 MACK CV...
2007 Jeep Commander (A62613)
2007 Jeep...
