Pat's Easy Change Hitch Sizing Question
/ Pat's Easy Change Hitch Sizing Question #1
Huntshillhaus Farm
South Central Missouri
John Deere 2150, Husqvarna Z554
I have a John Deere 2150 that I am planning to put a Pat's Easy Change Hitch assembly on. The issue is that, while the lift arms of the three point are structurally sized like Category I, the swivel balls are Category II. All of my implements (to this point) are Category I pins, and I use the Cat II/Cat I bushings on them.
Pat's come in several options, including Cat I/Cat I... Cat II/Cat I... and Cat II/Cat II. The Cat II utilizes the 1 1/8" pins (which my 2150 uses), but they seem vastly oversized for the arms themselves. The 7/8" Cat I pins are too small, obviously, but I am wondering if they would make more sense if I used the Cat I/Cat II bushings inside them?
I contacted Pat's directly, and their email indicated I should get the larger size, but I'm wondering if they fully understood my plan to use the bushings inside the swivel balls.
Any of you all out there had experience with this? Do I need to size up to the Cat II/Cat I (lift arm/implement) combo connector?
/ Pat's Easy Change Hitch Sizing Question #3
As long as the arms will physically fit in the Pat's ends then I would probably just go with the Cat. 1 set and use the bushing.
Just make width/height of the arm ends will work.
I was about to order the Cat 1, then saw this on AskTractorMike. Do any of you have the Cat 1 Pat's that could measure the inner width of the opening for me?
"NOTE: If the tractor has lower link arm balls that are both Category I and Category II (many Mahindra models have this option), order Pat’s Category II or Category II (tractor) to I (implement) models. Category I Pat’s Easy Change won’t fit because of the width of the balls."
/ Pat's Easy Change Hitch Sizing Question #5
The opening on my Pats measures about 1 3/4”. They are category 1. They are pretty loose on the arms and bolts hold them tight. I assume the extra width is to fit over the ball, which the width of the ball may be the critical measurement.
Awesome. That helps me out a lot! :)
Lol, now I'm back to square one. I was about to order the Cat 1 from Rural King, when I noticed in the specs on their website said the socket width was 1.5". So I called the Pat's guy direct, and he told me they are 1.25", (which makes no sense at all to me since the ball width for Cat 1 is 1 3/8"). Is there any possibility they changed the design spec since you ordered yours, Dave?
/ Pat's Easy Change Hitch Sizing Question #9
It possible. Everything is kind of covered up when they are installed. The measurement I gave you woukd the side closest to the tractor when installed, it could be smaller inside further closer to where the 3 point balls are.
/ Pat's Easy Change Hitch Sizing Question #10
Are yours the all cast or the earlier fabricated style?
I have the cast design, I'll try to get a measurment when I get home in the morning.
I just measure my ball width this morning, they are Cat 2, but are only 1.25 wide. Went ahead and ordered the Cat 1... fingers crossed.
What is the difference between the two? The only ones I see that are still fabricated are the Cat 1 to Cat 2, OR Cat 2 to Cat 1. Everything else is cast. Read somewhere that they are tested to 20,000+ lbs for the Cat 1, and 40,000 ibs for the Cat 2.
/ Pat's Easy Change Hitch Sizing Question #14
Nothing I can tell other then the manufacturing process. The early versions were fully fabricated, newer cat. 1 are cast, guessing it was more cost effective to cast the most popular cat. 1.
I'd guess they don't sell enough of the other models to get the casting made so they still fab those?
After conferring with AskTractorMike, I went with the Cat 1. Got them a couple of days ago, trimmed the 1-3/4" long Cat2/1 bushings down by 3/8", and put it all together. Worked like a charm.
/ Pat's Easy Change Hitch Sizing Question #16
Suggestion: double nut the u-bolt nuts.. My first mowing, I lost 3 of the 4 despite having torqued the nuts. Lots of vibration back there. I double nutted using a jam nut. No troubles since. Love the PATS...
/ Pat's Easy Change Hitch Sizing Question #17
When I bought mine years ago it came with double nuts for the U-bolts.
/ Pat's Easy Change Hitch Sizing Question #18
Love my pats also , I change implements alot when im at my farm on weekends . Pats makes it much less hassle.
Yes it came with double nuts, but I opted to bypass the for nylon locknuts as was recommended by several folks. I just hadn't put them on yet in the picture.
ALUMINUM HYDRAULIC TANK (A68842)
ALUMINUM HYDRAULIC...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2011 HUTCHISON CRUDE TRAILER (A67714)
2011 HUTCHISON...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
2016 Chevrolet Express Shuttle Bus (A66736)
2016 Chevrolet...
2011 Lexus IS250 Sedan (A66738)
2011 Lexus IS250...
