Tool box
/ Tool box #1
Massey convert
Massey Ferguson 2605 H
The tool box that Massey put on this tractor is ok for a screwdriver, crescent wrench and a pliers, but not much more, so I did this.
The box is some kind of ammo box and the frame holding it is 1/8 X 1 " angle iron mounted to the radiator guard with 3/8" bolts. Just to prove a point, I put all my weight on it, (200#s) tomake sure it wouldnt fall off.
/ Tool box #2
Interesting...can't recall seeing toolbox attach like that with front loader.
/ Tool box #4
That’s a nice big one. My tractors don’t have the clearance between the grill guard and FEL. Used 50cal boxes bolted to the ROPS. Carrying tools is essential for tractor work.
One note of caution is being under the FEL without a prop is risky. Commercial construction equipment usually has a easy to deploy brace on their loaders. Wish ag tractors would follow the same safety guidelines.
/ Tool box
I totally agree that being under the FEL is not good practice, I avoid going there. I lower the FEL to the ground before accessing the box, it's just easier, so I'm not tempted to get under the loader.
/ Tool box #6
Interesting. The Workmaster 40 has no toolbox at all, and I ordered an ammo box with the idea to do the same thing, since the loader sits far out in front of the tractor. Then thought maybe mount it elsewhere, but when it gets here I'll see if it works there..
/ Tool box
Miserable,
If you would like, I will take some more pictures of how I mounted it and the framework holding the box.
/ Tool box #8
Yep! Safety should reign.
I needed to do some work up front and what I did was to make some safety bars to keep my FEL elevated.
Not very difficult either.
I simply used some angle stock (old bed frame angle) and cut a tad shorter than the extended hydraulic cylinders.
Being in a hurry I simply used some duck tape to retain the angles in place.
That was a week ago and my FEL is still elevated and I feel safe under there working.
LOL, just waiting for it to get warmer to finish the repair chore that is programmed.
/ Tool box
That is a good idea. If you have to be under the loader, a mechanical barrier is the safest way to do it.
/ Tool box #10
Looks like a 20mm box. I have one too, but can't seem to find a good place to mount it on my lil' LX2610SU Kubota. Maybe I'll just use the box for a storage shed for the tractor ......
/ Tool box #11
Still need to mount a toolbox somewhere on the LS... Compact tractors not have many places. Thought I had one found on the back of the cab, but was completely in the way for hitching up implements.
Replacing right side step or clamping a box to the loader boom best options for me. The LS does not have the clearance in front between guard and loader boom.
/ Tool box #13
Hi all, I have a Kioti ck25 compact does anyone have any photos of a toolbox mounted somewhere on a compact tractor or an idea of what to use and where to mount it? Thanks in advance......🇺🇸✌🏻
UNUSED WOLVERINE SP-15-84W 84" SNOW PUSHER (A62131)
UNUSED WOLVERINE...
2020 Toyota Tacoma Pickup Truck, VIN # 5TFRX5GN2LX180496 (A61165)
2020 Toyota Tacoma...
TAKEUCHI-VIRNIG TRRG72 - 72" HYD ROOT RAKE GRAPPLE (A62129)
TAKEUCHI-VIRNIG...
2010 Dodge Charger Sedan (A61569)
2010 Dodge Charger...
UNUSED ATS EJ 11000 ELEC.JACK (A62131)
UNUSED ATS EJ...
iDrive TDS-2010H...
