My mini dozer build
/ My mini dozer build #21
So far not noticeably light in the back. The fuel tank is under the seat and the back and sides of it are 1/4 inch plate also the hydraulic motors add some weight back there. Originally when I started I was planning a front end loader but needed to move dirt on a new place sooner so bought a 2520 JD with FEL so I'm planning a six way dozer now for the crawler. There is an auxiliary hyd.pump built into the hydostat.pump that I will use for the dozer. Right now it's just returning to tank. Don't have a lot of pictures of the build but will send some of various parts.
Grill and some track frame parts.
Fuel tank fan shroud hyd.tank and front grill mountEngine and belt tightened bolted into frameView attachment 692473
Front idlers and drive sprockets
Did you find drive sprockets or build them yourself?? Tracks are from a??
Thanks for all the kind remarks everyone! And yes Smokeydog each track frame is held onto the main frame by 2 5/8 in.bolts making it very easy to service.
I looked for sprockets to buy but couldn't find big enough ones so I cut my own. My plasma won't cut 1 in material so I cut 1 main complete sprocket out of 1/2 in plate and another rim also out of the same. Welded them together to make 1 in.thick. Same with front idlers and all the rollers. Tracks are 300 mm width by 52.5mm pitch and 74 link if I remember right. They fit numerous machine 20210122_092234.jpg
Closer view of sprocket build. I used free software called sprocketeer. Very easy to design sprockets of any size or pitch. The trick I found out though is that a 52.5 mm track takes approx.a 50 mm sprocket because the thickness of the track doesn't allow the track to hinge on the center of a pin. I cut 3 or 4 trials out of 14 ga.before I got it right😀
Gonna share a little more of the start of the project which I should have done at the beginning of this post. I've thought of a project like this for a long time so when I ran across a fire damaged portable welder with a mostly undamaged Kubota engine for a reasonable price I bought it. A beautifull starting and running engine with 3400 hours! Next problem what size? I surely wanted it big enough to ride comfortably and do some usefull work. The engine had the front grill intact and looked like it could have dimensions to start with. I pictured a machine maybe 4 ft.wide and six ft.long. So sat down with Corel draw on my computer and came up with the following.20210329_161131.jpg
On the left is the size and shape of the original grill with some tracks sized to what I thought would look right. Now don't laugh anybody!! On the right I progressed to a side view with a six foot operator in block from to make sure he would fit. So here is how you start designing a dozer when you don't have an engineering degree🤣🤣!
/ My mini dozer build #25
You don't need to have a degree,,, if you look through history many, many people dropped out of school yet did great things. Some people will even argue that a engineer degree will quash peoples thought process and have written books about the stifling of great minds, that a university will do. Whatever the case, I've designed many things by looking at current machines and made improvements. Or at least attempted improvements. :LOL:
Where are the tracks from????
Thanks AlyA. I've never even wished for a degree. I've just happily invented all my life. I've always detested things that were hard to service but low and behold by the time I was done crowding the hydrostatic pump and motors into to small a space I've come close to doing it myself🤫
The tracks are from an outfit in Edmonton Alberta called Rubber Track Canada.
/ My mini dozer build #28
Camso and Soucy are by far the largest rubber track builders in the world but the real question I should have asked is "what machine are the tracks made for?"
/ My mini dozer build #29
Late to the party here but did you complete a blade for it or other attachments or implements? The machine looks great.
Working on a blade right now. Gonna be six way hydraulic. Bought a 2 spool joystick already for lift and angle and need to get a solenoid operated diverter valve for the tilt.
A little more progress today.
Some shots of A frame and mounting.
If I remember right they fit a 320 Bobcat mini hoe not altogether sure on that. I think they must be China made. All I can find on them is xtreme and than the size. They do fit a number of machines.
/ My mini dozer build #32
What will you attach the blade with?? Pisten Bullys use a spherical ball joint. When I built an all-way blade for a snow machine I didn't, but I should have....
/ My mini dozer build #34
I'm not seeing how those could work. Here is the spherical bearing that bully uses. Up close and further back. Its at the center of the balde and allows X degress of blade moveemnt. How could your 2 bearings at separate locations do something similar???
I guess we're talking two different things. I'm talking the dozer frame up and down swivel and you are on the tilt swivel. I'm making the pieces for that today will have some pictures soon.😃
The way I'm used to it here is a six way dozer will move up and down, angle sideways as in pushing snow or dirt sideways,and tilt corners up and down. Are we talking the same thing?
/ My mini dozer build #38
Now that I think about it, yours is not all-way. (slow thinker?) Snow machine blades can vary there's on one more plain. The top of it can be made closer to, or further from, the operator. That's what the single, top cyclinder does.
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
Western 8.5 Pro Plus Ultra Mount (A62679)
Western 8.5 Pro...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
New/Unused Wolverine Sickle Bar Mower (A65583)
New/Unused...
2022 EZ-GO ELITE...
